Sent to referee to smog check
Old Mar 30, 2020 | 01:35 PM
  #31
kamlung's Avatar
5 Year Member
kamlung is a name known to allkamlung is a name known to allkamlung is a name known to allkamlung is a name known to allkamlung is a name known to allkamlung is a name known to all
bro why you showing ppl my car?
dat taillight doe...
Old Mar 30, 2020 | 05:07 PM
  #32
HotRodGuy's Avatar
the bumper is the bet
Old May 11, 2020 | 12:23 PM
  #33
wahid's Avatar
wahid is infamous around these parts
With Covid-19 the referee are doing phone appointments prior to an in person appointment, so it has taken time to get answers.
My reason for being flagged to go to the referee is that my ECU profile (taken during my previous smog test two years ago) does not match any other car like it in the state of CA which shows the ECU does not have the factory flash. I'll need to show them an invoice for work done to reflash the factory image and then I can get an appointment to get it inspected/tested at the referee.
Old May 11, 2020 | 11:24 PM
  #34
'02996ttx50's Avatar
you do realize, that running a modified porsche turbo in los angeles or oc will soon be more difficult than grocery shopping without a face mask, yes?
good luck.
Old May 12, 2020 | 06:43 AM
  #35
HotRodGuy's Avatar
what's changing?
Old May 12, 2020 | 10:19 PM
  #36
jayzbird's Avatar
jayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to behold
So I guess this means everyone will have to revert back to stock for smog checks. Not such a big deal I guess for folks with a Cobb, etc. but not sure how the older ECU mods that were once and done will cope.
Old May 13, 2020 | 10:51 AM
  #37
nbressette's Avatar
nbressette has much to be proud ofnbressette has much to be proud ofnbressette has much to be proud ofnbressette has much to be proud ofnbressette has much to be proud ofnbressette has much to be proud ofnbressette has much to be proud ofnbressette has much to be proud ofnbressette has much to be proud ofnbressette has much to be proud of
Depends on how the tune was done. Cobb simply modifies the tables on the existing rom ID. Older methods actually used foreign rom IDs that shouldn't ever have been on a car sold in the US. Verifying expected ROM IDs and flagging any rom ID that isn't on the OEMs list of US market ROM IDs is easy, I really doubt they are doing checksum comparisons.
Old May 13, 2020 | 11:48 AM
  #38
Road King's Avatar
Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !
I reverted to the stock Cobb tune for my last smog check and had no problems. I checked all the readiness codes in advance and all were set....
But yeah, this $hite ain't getting any easier here in the People's Republic.
Old May 13, 2020 | 11:53 AM
  #39
wahid's Avatar
In the notification I received, If my car is factory reflashed by anyone other than a dealer, I need to send the ref a photo from a tool showing the CAL ID and CAL CVN numbers before I can get the appointment for the car inspection. I guess once I'm at the referee appointment they will also check these themselves but want to reduce wasted appointments. I may be stuck going to a dealer as I don't know what tool can show the CAL ID and CAL CVN.
Old May 13, 2020 | 03:13 PM
  #40
nightmare. i go through this **** every two years. i have a full 12 months to go and am already dreading next years reg process.
i swear ..and to road kings point. CA is making this as difficult for anyone with a car that has any aftermarket parts or whatever as "they" can. it's not about "air quaility" per se. good luck man. i feel your pain.
Old May 13, 2020 | 03:28 PM
  #41
nbressette's Avatar
What rom ID are you running? This could be a win-win with a chance to get on a modern rom ID that has superior programming and then work with a cobb tuner to get a modern tune that is easily revertible.
The dealer shouldn't charge much more than 1hour labor to flash the latest rom.
Old May 13, 2020 | 03:45 PM
  #42
wahid's Avatar
I've no idea what the original ROM is but assume it is whatever 2001 came with. Newer could be better. Do you know of a dealer that only charges an hour or two to flash?
Old May 13, 2020 | 05:18 PM
  #43
any porsche dealer should only charge one hour to flash back to the stock map. its no more difficult than programming a key remote or whatever.
Old May 30, 2020 | 02:28 AM
  #44
01Turbo's Avatar
5 Year Member
01Turbo is a name known to all01Turbo is a name known to all01Turbo is a name known to all01Turbo is a name known to all01Turbo is a name known to all01Turbo is a name known to all
Thanks to this thread i dont feel singled out or crazy. i too had the surprise of going to state ref. I made sure my car was in good working order and now i am back into the normal 2 year rotation. If i had to guess, it might be ROMID comparison or maybe i was on the list of cars that went to a smog shop was being under surveillance.
Old May 30, 2020 | 04:05 AM
  #45
infinkc's Avatar
infinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to behold
wow that’s crazy, is your car tuned?
I just went to a smog shop, they failed me for aftermarket diverters. I had removed my exhaust prior also. They are getting super picky now, didn’t like my silicone hoses either. They said anything not stock now they will flag. Best to ask them now before you test. This is getting crazy.
