Stuck Engine Latch Fix
Old May 8, 2020 | 10:17 AM
mezger man's Avatar
mezger man is infamous around these parts
I was able to fix the stuck latch today. I wedged a rubber spatula between the hood and the bumper. i hit the switch and the latch popped open. i then adjusted the hood adjustors on either side of the hood. It works like its supposed to now.
Old May 8, 2020 | 05:20 PM
'02996ttx50's Avatar
yeah people forget ( or never knew ) that the adjusters can interfere with the latch popping.
spatula? first time i've heard of that ha. ingenuity.
Old May 8, 2020 | 05:57 PM
mezger man's Avatar
I just figured I'd try that instead of propping up the tail light to fish out the manual pull cable and it worked. I should make a You tube video and show that it took 20 seconds to fix it.
Old May 8, 2020 | 08:57 PM
now im confused. taillight? you mean the manual cable in front? if so i re-routed mine it now lays tucked inside the seam of the headlamp enclosure passenger side. all it takes is a needle nose to fish it out as ( if ) needed.
Old May 8, 2020 | 10:00 PM
Stebo's Avatar
Stebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond repute
There is also one in the back for the engine lid
Old May 9, 2020 | 06:31 AM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
yup after reading I went out and adjusted mine again, they flatten/harden a bit over time I suspect........
Old May 9, 2020 | 05:57 PM
yes, thanks. i of course know that. for whatever reason i assumed he was talking about the front since he said "i hit the switch and the latch popped open. i then adjusted the hood adjustors on either side of the hood."
and while i know where the cable is front and rear. i've never seen hood height adjusters on the rear decklid. hence my ( reasonable, given his phrasing ) confusion lol
Old May 10, 2020 | 01:29 AM
mezger man's Avatar
You've never seen the adjusters on either side of the rear hood? I don't think I've ever seen a car without them.
Old May 10, 2020 | 05:10 PM
no never have. nor have i had to mess with the rear struts ever. learn something ( nearly ) every day!
Old May 11, 2020 | 05:28 AM
mezger man's Avatar
After searching the Forums I found many people with the same problem. Now I can do an easy fix if it happens again.
jlasinski
Mar 10, 2020 01:55 PM
rich022
Cayenne 958
Jun 1, 2019 11:01 AM
Prefurbia
Jan 16, 2018 12:41 PM
Gary in BR
Jul 5, 2010 05:57 PM
PorscheEnvy
Nov 16, 2007 09:42 PM
