Ruf front bumper installation
Center radiator removed and left hose changed. Original line removed
After all ducting installed.
Close up of new hose installed
Original right hose which will be removed with new hose
Center radiator installed again. Notice forward tilt.
All ducting installed.
you need both hoses from a gt2 since the center radiator will be flipped and the inlet and outlet will be raised. On a gt2, the coolant flows from the outer radiator, to center to other side. This is not the case on a turbo
Do you have the part numbers for those 2 hoses by chance? I do have a turbo with a precision GT2 bumper. I'm ordering the chimney and the side radiator brackets.
