Where rims and tires sizes do all you guys that have 19" wheels?
Old Mar 16, 2006 | 04:41 PM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
So putting a 315/25/19 tire on a 19 in. x 12 inch rim is not a good idea? If not, are 325/25/19 or 335/25/19 tires available and would they clear?
Old Mar 16, 2006 | 04:47 PM
damon@tirerack's Avatar
Moderator
Originally Posted by DeeMan007
Arling,
Would you run 305/25/19 on a 19X11 rear wheel and if so, what tires would you use then? Thanks!
Pirelli Rosso is the only one available.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Mar 16, 2006 | 04:55 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Sounds like you've already bought some 12" rims and are trying to make em work
Old Mar 16, 2006 | 05:01 PM
20C4S's Avatar
Arling,
run that size all the time for narrow C2s. it fits nicely on 11'' wide wheel but like Damon said only Pirelli makes it in that size & it's expensive.
depends on ur rear wheel offset because if u are, or have to run an aggressive camber in the rear & drive the car daily i'd go for Conti because of the cost issue. ur inner tire will chew to core sooner than u expected. if cost is not a concern then go with the Michelin PS2. it's a better performance tire than Conti CS2. for those of u who want run wider wheel the PS2 315/25-19 fits nicely on 11.5'' wide wheel.
Old Mar 16, 2006 | 05:52 PM
Not yet... The reason I ask because some wheel makers don't offer half sizes and i don't want to buy an 19x11.
Old Mar 16, 2006 | 06:00 PM
GreggT's Avatar
And what do we have against 11s?
Old Mar 16, 2006 | 06:19 PM
Because it seems that a 315/25/19 doesnt fit nicely on a 19x11 rim and more importanly...I like BIG LIPS...
Old Mar 16, 2006 | 09:59 PM
Wheel Experts's Avatar
In certain offsets the 19x11 with the 315/25 rubs. The 11.5s usually allow the tire to stretch out to the fullest (without OVERstretching the tires for that nasty slanted sidewall look) so they will fit w/o rubbing.
Most wheel makes that are custom can build a 11.5. If they can make a 11 and they can make a 12 then they SHOULD be able to make a 11.5....at least all the companies I know of.
I agree with Arling - the 305/25 Pirelli Rosso is best suited for the narrow body C2/C4 on a 19x11, while the Conti 315/25 on a 11.5 is the best bet for the TT/C4S.
Old Mar 16, 2006 | 10:32 PM
GreggT's Avatar
Just my opin but.......I don't think that's incorrect.....seen lots of 315 PS2s on 11Js that fit very 'nicely'........but it's your car, definately make it look the way you want.
On the BIG LIPS, keep in mind they are as much a result (or function) of wheel style and offset, as they are of that 1/2 inch.
Old Mar 16, 2006 | 10:43 PM
yokohama avs sport run about 1 inch tinnr then any standard tire... I know casue I had them.. and that was on a 12 inch rim... way to narrow... then I went with conti sports and they were considerably wider.... both 315s. so a yokohama 315 will fit very well on a 11 inch rim...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 16, 2006 | 11:48 PM
LSM's Avatar
LSM
Senior Member
LSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of lightLSM is a glorious beacon of light
My Turbo S has been sold for some time now, however, at the time, I was running 8.5x19 and 11.5x19 with 235/35/19 fronts and 315/25/19 rears...Michelin PS2's
Old Mar 17, 2006 | 01:54 AM
Wow, that is just beautiful... I had 547Rs on my M3 too.
Old Mar 17, 2006 | 01:55 AM
Quick question, are there possible rubbing issues by going with a 19x9 with a 245/35/19 tire up front or is 19x8.5 with a 235/35/19 as wide as you can go?
Old Mar 17, 2006 | 02:01 AM
20C4S's Avatar
will rub. not the fender but the area in front of & behind the wheel, especially when u turn lock to lock.
Old Mar 17, 2006 | 02:44 AM
a 19x9 with a 235 will not rub I know cause I have it... and thats with a pss9 suspension as well.
9.66
click to view
