Wiring for OEM wing
Old Jan 18, 2022 | 02:18 AM
hbn's Avatar
hbn
hbn is infamous around these parts
Wiring for OEM wing
Bought a used stock hydraulic wing. The wire harness connecting it to the car has been cut.
I searched wiring diagrams, but neither colors nor number of wires match 100%..
If anyone could post some close up photos of the colored wires going in to the socket, that shows what wire is going to what pin, i'd be very grateful.
Old Jan 18, 2022 | 10:45 AM
jpflip's Avatar
I got a spare system and took these pictures, hope this help! Let me know if you need some more pictures...
Old Jan 18, 2022 | 11:23 AM
hbn's Avatar
hbn
Thank you so much!
To make sure, from left to right,
1st pic:
Blue/green
All Grey ?
Yellow/green
All Blue?
All Brown?2nd pic:
Brown
Black
Blue/red
Red/brown
Black/orange
correct?
b/c I have two wires that are Grey/green and Grey/brown..
Old Jan 18, 2022 | 01:12 PM
jpflip's Avatar
1st pic:
Blue/green yes
All Grey ? yes
Yellow/green yes
All Blue? yes
All Brown?2nd pic: Yes but smaller size wire.
2st pic:
Brown yes
Black yes
Blue/red yes
Red/brown yes
Black/brown yes
Old Jan 18, 2022 | 01:15 PM
hbn's Avatar
hbn
Thank you very much!
Old Jan 18, 2022 | 01:19 PM
jpflip's Avatar
I went to check continuity between various plugs and the main plug. Here's the result: (sometime confusing because some of the wires got continuity to several pins on the main plug...)
First plug, I think it is for the light in the engine compartment : wires on this small plug are first the red/blue and it goes top the main plug red/blue and the other is red/brown and it goes to red/brown on the main plug.....
Old Jan 18, 2022 | 01:22 PM
jpflip's Avatar
The second plug, I think it is for the engine compartment fan: Got two wires and the first one solid black and it goes to solid black on the main plug. The other is solid brown and it goes to solid brown on the main plug....
Old Jan 18, 2022 | 01:30 PM
jpflip's Avatar
the third plug, I cannot remember what it does: Two wires. The first one is solid brown (smaller size wire) it continuity goes to three pins on the main plug: green/blue, blue solid and brown solid. The other wire which is black/brown goes to black/brown on the plug....
Old Jan 18, 2022 | 01:34 PM
jpflip's Avatar
The big and red wires for the power to the spoiler motor are connected to : Red to yellow/green of the main plug and the black to green/ blue of the main plug....
Old Jan 18, 2022 | 01:45 PM
jpflip's Avatar
Now it get more complicated: The switches on the spoiler actuator..... The wires from both switches top and bottom are blue and black....I am unable to check the continuity of the lower switch because the wire is too small to put a needle through it without damagind the wire, sorry. But the top swich, those two wires, the blue one and the black one, blue change to one solid grey and the black stay solid black.... The blue continuity goes to three pins the main plug , grey wire, blue wire and small brown wire....The black wires continuity goes to three pins of the main plug which are : grey wire, blue wire and brown wire..... There is also a red wire only on the top switch but I cannot remember what it is for ?????
Old Jan 18, 2022 | 01:49 PM
jpflip's Avatar
If you need me to check something else, I got the complete system on a bench easily accessible, J.P.
Old Jan 18, 2022 | 02:22 PM
jpflip's Avatar
I dont want to confuse you more but when you said you have two extra wires with no matching colors, I went to check the actual system on my car and found something very interesting , some other colors ;-(
Female part on the plug both sides
Male portion of the plug both sides....
Old Jan 19, 2022 | 02:19 AM
hbn's Avatar
hbn
Thank you so much, you’ve been an invaluable help!
Old Jan 19, 2022 | 05:20 AM
jpflip's Avatar
Good luck with this challenge! J.P.
bmw2nv2000
Feb 24, 2016 10:20 PM
Kris79
Jul 10, 2012 07:37 AM
