2021 Thoughts on Meth Injection?
Starting to get the itch again for more power. Currently on early gen Tial A28s, ID 1k injectors, 200cel cats, and 1.2bar Cobb tune. This puts me at the conservative limits of CA 91 octane fuel. I don't track the car and it's more for fun around town when I'm in the mood, serving DD about half the week with my other DD.
What's the latest thinking on Meth injection? 50/50 or even full water injection? Which kit to go for that has good/easy integration with the 996 electronics?
I'm not looking to necessarily tune for that much more power. Perhaps a minor bump to boost or timing as my setup is still conservative. Just more safe octane and benefits of cooling to stay well away from knock to compensate for low octane 91 gas.
Stock rods.
I'm not looking to push past 600hp. More that I'm looking for more safe margin and to optimize current performance with only 91 octane.
What's a good meth injection kit these days?
It's not about specific HP level really. I'm interested in meth injection for more potential and safe margin from lowly 91 octane.
Question still stands. What's the current recommendation for meth injection kits? Nozzle sizing for ~600hp?
Out her in CA I wouldn't do it, as it is becoming more difficult to smog your car, surely a methanol injection system would be a major red flag, and would likely be hard to hide, or at least a pain the ***.
There are some good threads in the forum.
Thanks and this helps. I've been digging into this and many of the more modern Porsches also use Aquamist, and also Snow and AEM. They have varied degrees of complexity and failsafe's, and none seem to be more easily or readily integrated.
I'm looking to do meth to kill 3 birds with one stone. Supplemented octane for more stable ignition timing on hot days, cooler and safer IATs for more safe margin, and potentially more room to turn up the wick later if I so choose Personally, 91 octane IMO is just not enough for even 550hp. I still have stock intercoolers, and it would be reasonable to upgrade these GT2RS units, but from what I've seen with meth or even plain water injection, the cooling effects are much beyond what's possible with upgraded intercoolers. Plus I only run on the street so I'm not heat soaking the intercoolers like it would on track.
I may try something different with all of this which is to setup fender intakes with a MAFless tune I already have. Then put all the meth pump/bottle/stuff in a second stock spare intake box that I have. This should keep everything tidy with a single meth line running the underside of the Y-pipe ahead of the throttle body. And a harness that's tapped into the requisite electrical lines.
You bring up a good point with smog. All this should can be reverted easily enough - back to regular intake, remove meth line leaving nozzle on underside, flash back to MAF tune.
If I lived in a state with 93 octane, this would be different. In CA, we pay a premium for gas, that then tops out a 91 octane. When even stage 1 tunes need to tailored for ACN91 (Arizona, California, Nevada 91) versus rest of the states that have readily available 93, that's not enough octane for stable timing at higher HP levels.
I'm a meth addict. It's not a pain and nothing to mess with if it's set up right. You can gain 30-50whp with some conservative tuning, and with aggressive tuning, you can gain 60-80whp...been there done that...still doing it...
Care to share your set up? Pics or a write-up?
Old 996tt from 10 years ago...search this forum for my screen name. Had an Aquamist kit. Tons of info...Went a different route on my current Meth kit, but still recommend Aquamist, if you can find one.
Here is my client on k16 billets with our supporting mods and custom tuning - 93 octane and meth made 656 rwhp on dynoject.
656rwhp/630rwtq
656rwhp/630rwtq
2001 996TT 3.6L and stock ECU
