100ll Avgas?
Old Mar 19, 2006 | 12:10 PM
whorespower's Avatar
whorespower is infamous around these parts
100ll Avgas?
Anyone have experience with this stuff. I run 110 leaded race gas periodically w/good results. I was told 100LL avgas was good as well. My car is running ****ty now.
Old Mar 19, 2006 | 12:20 PM
if u run leaded gas u will fowl ur O2 sensors. I run 100 unleaded for the race program I have.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 19, 2006 | 12:27 PM
From what I am reading avgas has a lower volatility and burns slower....would explain the sputtering
Old Mar 19, 2006 | 12:58 PM
benguss's Avatar
benguss is infamous around these parts
higher the octane the more you can compress it without detonating it. It's kind of reverse to put it simply. So in a sense it is LESS volatile than lower octane gas. Also putting AVGAS in modern cars is not very good. In older cars as in the 60's with big engines designed for leaded gas not a problem. But modern engine sensors ie. cats, O2 , and a host of air inlets/outlets and check valves will will be contaminated. AVGAS contains antiicing agents and PRIST which is an additive which inhibits microb/bacterial growth.
Old Mar 19, 2006 | 01:03 PM
Michael W.'s Avatar
Michael W. is infamous around these partsMichael W. is infamous around these parts
Are you sure?!?! I was under the impression PRIST and anti-icing agents are only added to jet fuel, not regular AVGAS.
-- Michael
Old Mar 19, 2006 | 01:09 PM
benguss's Avatar
You are right, I forgot. Jet fuel must have them and avgas is on request only, but lots of places will put these agents in the avgas and charge you for it.
Old Mar 19, 2006 | 08:20 PM
shonuf's Avatar
Member
shonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to behold
not only will you ruin your oxygen sensors but the catalysts as well. ouch.
carlos
olwe
Mar 30, 2014 02:11 PM
rickyj
Mar 29, 2014 10:47 PM
contigo
Track & Autocross
Aug 17, 2008 09:46 PM
