996 TT spoiler failure message
Old May 8, 2025 | 05:40 AM
maxrod's Avatar
maxrod is infamous around these partsmaxrod is infamous around these parts
Just purchased a 2004 TT to keep my X50 company. 😁.
I just got a messaged displayed showing Failure Spoiler Control. The spoiler works. I tested and it goes up and down anddd there are no fluid leaks.
Anyone have an idea? I am thinking maybe is a relay gone bad.
Old May 8, 2025 | 03:34 PM
maxrod's Avatar
WOuld anyone know the Bosch part number for the Spoler Relay? Porsche is 996-615-102-02
Old May 14, 2025 | 06:12 PM
jcam's Avatar
jcam is a splendid one to beholdjcam is a splendid one to beholdjcam is a splendid one to beholdjcam is a splendid one to beholdjcam is a splendid one to beholdjcam is a splendid one to beholdjcam is a splendid one to behold
When my 996 TT X-50 first gave me that error message, I took it to Dan Aspesi at the Speed Gallery. Who at the time was helping another customer, though was able to diagnose the problem and quote me a price to fix it while just walking by my car. I probably was looking at him incredulously, so he came back a moment later, lifted the rear lid and ran his finger over the surface of one of the pistons, displaying the leaking hydraulic fluid. Unfortunately the problem is that common with the wing lifts. I would recommend that you read the threads in this forum regarding the rear wing. I'm currently using Dave Cooper's Rennkit lifts, it's worked well for me over the years.
Old May 14, 2025 | 06:44 PM
maxrod's Avatar
Thank you. In my case, there is no fluid leakeage at all. Spolier goes up and down manually w/o a problem. So I am thinking the following: 1) one of the relays are bad or 2) the microswitch is bad. Will replace the relays first, and then the switch. If that does not solve it, then going the way of the electrict lifts.
I appreciate your reply
Old May 16, 2025 | 05:00 AM
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
Check the microswitches. The other issue is that very minor fluid leakage may go undetected. If the right side is low on fluid the upper microswitch will not engage.
Old May 16, 2025 | 06:12 AM
maxrod's Avatar
Thank you Dave. Are you saying replace or check the MSs? If checking, what do I check for? I was thinking of first spray some solvent then maybe WD40
Old Jul 8, 2025 | 03:05 PM
maxrod's Avatar
So here is what I discovered today. I removed the hardtop which I needed as part of the strut replacement. I started to drive, hit the 76+ mph and got the error light. The spoiler was up as it should. However, reducing speed did not lowered the spoiler automatically, but could with the switch. So I am scraching my head.
As I already checked for leaks (none), cleaned the micro switches. Next is to replace relays and see.
Any other ideas are welcome.
Old Jul 8, 2025 | 03:20 PM
If you got the warning at 75 MPH, then the top microswitch was not activated, meaning the system is slightly low in fluid, or the gray wire on the right ram (top switch) did not send the signal back to the dash cluster ECU. You may want to fill and bleed the system. There are several procedures out there. One guy claims removing the lid is the easiest way. I'm not so sure...
Dave
Rennkit
Old Jul 8, 2025 | 03:29 PM
maxrod's Avatar
Thank you. But why would I get the message if the Spoiler was up as it should? Will search for the "how to fill". I am sure it will be a pain
Old Jul 8, 2025 | 03:32 PM
if low on fluid, wing is up, but not quite all the way...
Old Jul 8, 2025 | 04:10 PM
maxrod's Avatar
I believe you are right. I came back after lunch from my ride and while driving, I could see the spoiler up. Got home and did not check anything. Just went out to walk my four legged kids and saw this. The left side was lower than the right. I might have to switch to electrics if I cannot find a way to refill.
Thank you Dave
Mpsuk
Dec 9, 2017 08:32 PM
sjclough
Dec 12, 2013 09:34 PM
twinturbo007
Sep 6, 2009 09:06 AM
911mike
Jul 12, 2008 06:07 AM
