Can You Disable That Think When Rpm Is On high at Red Line?
Old Apr 24, 2006 | 08:41 PM
Billystang's Avatar
Billystang is infamous around these parts
Question Can You Disable That Think When Rpm Is On high at Red Line?
I PUT FIRST GEAR AND I SPIN THE WHEELS ,RPMS ABOUT 4-5K AND CAR DIES,
LIKE YOU CUT THE POWER, THEN SECOND GEAR GOES BETTER ,BUT I THINK MANUFACTURE HAS SOMETHING WHEN THE RPMS GOES TO HIGH CUTS THE GAS OR POWER,SO THE ENGINE WILL NOT SIEZE.
ANYONE KNOWS ANYTHING ABOUT THAT?CAN I DISABLE THAT?
SORRY I CANT EXPLAIN MUCH BETTER.
THANK YHOU IN ADVANCE
UPGRADES:
UPSOLUTE CHIP
PSI EXCHAUST
DIV VALVES
EVO V FLOW FILTER
Old Apr 24, 2006 | 09:09 PM
tom kerr's Avatar
Billy, I thought this was happening to me also in first and second gear. I realized later that my 4-5k was probably 6-7k at the limiter and I just couldnt see it. With an after market exhaust, LWFW ect the car accelerates so fast in first and second gear they are almost useless. Look again, I bet the revs are higher that you think!!
Old Apr 24, 2006 | 09:24 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
If you're spinning the wheels, you should invest in some better tires.
Old Apr 25, 2006 | 01:28 AM
ebaker's Avatar
ebaker is infamous around these parts
You probably over revved it.
Old Apr 25, 2006 | 09:10 AM
Billystang's Avatar
i have brand new contisupercontact2.
now about the rpms maybe higher i will check again.
thank you guys!
Old Apr 25, 2006 | 09:27 AM
thank you guys!
Get a softer rubber tire next time. The one's you have have little traction compared to many.
Old Apr 25, 2006 | 09:38 AM
kiko's Avatar
kiko is infamous around these parts
The thing is that you're actually doing 6750revs but the tacho is still reading 5k to 6krevs as its slower than the engine actually rev in the first gear (2nd gear as well on highly tuned cars). This obviously applies if you turned the PSM off. This is not new, it has been discussed before.
Old Apr 25, 2006 | 09:47 AM
egbert's Avatar
egbert is infamous around these parts
turn the traction control off.
Old Apr 25, 2006 | 09:52 AM
cjv's Avatar
cjv
Moderator
It is my understanding first gear has a rev limiter at 5800. Power is cut and you will get way past it with momentum. Imagine what would happen if the limiter for first didn't engauge until 6800.
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
alevine
Nov 4, 2015 10:05 AM
ModBargains
Aug 20, 2015 12:28 PM
