Full boost...no power
Old May 7, 2006 | 09:02 AM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
Question Full boost...no power
I assume I blew a hose today in the way to work. WOT in 4th gear...no one on the highway and the car just bucked and it felt like it only had about 100hp. Boost gauge climbs, have some power...but definitely not full power. No CEL's.
My question is...is it easy to access the boost hoses going to the intercoolers? I have never tried. Up top the hoses seem fine and snug. Thanks for any info.
Old May 7, 2006 | 11:00 AM
Griza's Avatar
Griza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud of
Surprising you did not get any CEL's Most likely a hose....hopefully...
Old May 7, 2006 | 11:02 AM
M3CAB's Avatar
I hope so....this is annoying with no power.
Old May 7, 2006 | 11:07 AM
Zippy's Avatar
What boost are you running? Is it possible you had throttle body shut down? When that happens it is a SERIOUS "buck"!
Old May 7, 2006 | 11:08 AM
M3CAB's Avatar
Tried to get back on it, and the car was very sluggish...boost gauge went back up to 1.3 then to 1.2....but almost makes me feel like only 1 turbo is working.
Old May 7, 2006 | 11:29 AM
Zippy's Avatar
What programming are you running? Do you have the throttle body shut-down fix? If not, you will have big problems if your showing 1.3 bar (been there).
Old May 7, 2006 | 11:31 AM
M3CAB's Avatar
Giac stage II. Not sure of the throttle body fix. Never knew about it.
Old May 7, 2006 | 12:46 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Have you done the hoses yet? Take off the bumper and check your hoses
Old May 7, 2006 | 12:50 PM
M3CAB's Avatar
can I access the hoses from removing the rear tires and fender linings?
Old May 7, 2006 | 12:51 PM
jags911tt's Avatar
Yes but removing the bumper is easier.
Old May 7, 2006 | 01:04 PM
M3CAB's Avatar
Now my question is....is it easy to take the rear bumper off? I did the front Techart II install myself, but never ventured into the rear bumper area.
Old May 7, 2006 | 01:29 PM
dyu2118's Avatar
dyu2118 is infamous around these parts
The boost hose by the rear passenger side tire popped off yesterday on my car. Took it to Pep Boys, had them put the car on a lift, told them to reconnect the loose hose. The guy there was cool....fixed it in 5 minutes and didn't charge me for it.
Old May 7, 2006 | 01:33 PM
M3CAB's Avatar
Thanks, did you have to remove anything to get to the hose?
Old May 7, 2006 | 01:35 PM
dyu2118's Avatar
Nope...you just need to put your car on a lift and access the area from underneath. Pretty simple stuff.
Old May 7, 2006 | 02:58 PM
M3CAB's Avatar
Thanks, just checked, and it seems all hoses are intact and in well. Can the car go into a limp mode with no CEL? I have not driven the car since this happened since I am still at work. Thinking a restart may clear any problems.
