Dyno Conversion number?
Old May 15, 2006 | 12:50 AM
willcoxmd's Avatar
willcoxmd is infamous around these partswillcoxmd is infamous around these parts
Hey guys,
Going to put my car on a Dynojet soon. I know the front tires just spin on some rollers. My stage 4 package from Evo is suppose to produce 600 HP at the crank. what kind of numbers should I expect from the dyno run at the rear wheels? I know there is a conversion factor...anyone have experience?
thanks
Old May 15, 2006 | 03:27 AM
Turbo Fanatic's Avatar
Be sure the rollers are connected with gears. Otherwise you WILL blow the viscous coupling....
My stage 3 put down 516 RWHP with the frond driveshfat disconnected with the 91 octane program. I would say divide by 87.5 or .85 depnding on whether you figure 15% or 12.5% drivetrain loss.
Old May 15, 2006 | 05:07 AM
12.5% loss on a 2 wheel... and 17.5% on a 4 wheel dyno. thast what EVOMS uses on their dynos and their HP packages..... so I suggest u do the same...
u need to hit about 532 rwhp to have a 600 hp crank car.
good luck...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 15, 2006 | 05:32 AM
kiko's Avatar
kiko is infamous around these parts
Does anyone here knows Rotronics dyno's? I'm not sure if all 4 wheels are connected on this dyno. (There are very few of them here in Europe as they're absurdly expensive but I was told they're the most precise of all)
http://www.rotronics.com/PDF_Public/...KP_08_05_I.pdf
EDIT: JUST READ THE LINK AND THEY'RE GEARED!!!
keeperofbeasts
11
Apr 3, 2017 10:53 AM
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
petron5000
Sep 6, 2015 11:20 AM
Suds26
Sep 2, 2015 01:33 PM
