In shock...474hp at the dyno
Old May 25, 2006 | 10:22 PM
drjoe's Avatar
drjoe is a jewel in the roughdrjoe is a jewel in the roughdrjoe is a jewel in the roughdrjoe is a jewel in the rough
usually dyno numbers tell you how much more hp your mods give you...do you have a base line (no mods)...otherwise this number (your current hp)can be very subjective when compared to other turbos.
Old May 25, 2006 | 10:24 PM
wross996TT's Avatar
OK to clarify...those are stock K16 turbos (not X50). I had the GIAC programming, but flashed back to stock. Like I said...I'm in shock. I can not believe the numbers, but three pulls on the dyno. I can't wait to see what happens after the mods. My mechanic was also surprised...he said it was running lean so it should have done better than that...maybe I got a stock turbo on steroids. BTW the reason I did it was to see how much the mods gave me...not for some other comparison.
Old May 25, 2006 | 10:29 PM
BlackBear's Avatar
BlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud of
If the car is already running lean there is NO more room for a chip to help you.
Lean = Power
Rich = Safe
You are running in danger territory if you are lean.
BUT, the above statements make no sense. An exhaust and intake should make your car Rich. Then a tuner then goes in and makes it lean again. This is how power is made.
Maybe your mechanic got rich and lean confused?
Old May 25, 2006 | 10:32 PM
wross996TT's Avatar
I don't think so...he is very knowledgable.
Old May 25, 2006 | 10:34 PM
wross996TT's Avatar
I agree...The reason for the dyno was to check before and after (the mods) I was just totally surprised. Not trying to say anything else!
Old May 25, 2006 | 10:35 PM
lithium's Avatar
lithium is infamous around these parts
Originally Posted by Hamann7
What that means is that Dynojet numbers are far more optimistic than a brake engine dyno or a MAHA dyno used by the German tuners.
Old May 25, 2006 | 10:56 PM
474 rwhp is obo 530+ hp to the crank... how is that possible when stage 4 with k24s duno 570 crank???
Im sure some of the tuners can chime in .
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 25, 2006 | 11:37 PM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
If your car already dyno'd at 474HP before the mods, then you are going to be very disappointed when you put them on and get the same numbers
I have the k16/24's, GIAC II, intake plenum, port and polished headers, bla bla bla, and my car dyno'd at 475 on 100 octane.
Old May 25, 2006 | 11:54 PM
Zippy's Avatar
...BUT, the above statements make no sense. An exhaust and intake should make your car Rich...
I beg to differ. The exhaust & intake will allow more air to flow throught the system. This has to induce a lean condition. But then again, what the F#@& do I know!
But I did sleep at a Holiday Inn last night!
Old May 25, 2006 | 11:55 PM
wross996TT's Avatar
Classic...I can't stop laughing!
Old May 26, 2006 | 12:02 AM
jaykla's Avatar
jaykla is a jewel in the roughjaykla is a jewel in the roughjaykla is a jewel in the rough
Maybe it didn't "flash back to stock" correctly and stayed in the performance mode?
Old May 26, 2006 | 12:06 AM
wross996TT's Avatar
No, actually I drove it for a while to make sure it was stock...boosted .7 with a spike at .8. I was getting 1.1 boost with 1.2 spikes with the GIAC program.
Old May 26, 2006 | 12:09 AM
wross996TT's Avatar
Actually that is what I was thinking on the other hand...maybe I'll just be . I don't think There will be any way I get the same numbers...but I would love to know what I would get with the GIAC program. Oh well I'll never know!
Old May 26, 2006 | 01:25 AM
Jean's Avatar
Jean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond repute
Wross996TT
I don't know who your tuner is, so this is not going against anyone, but the K16s will give you around 450-460 FWHP (Flywheel) maximum on the 996TT regardless of how good your programming is, they just cannot flow more.
If your car is running lean you should be seeing normally more torque on the dyno not less, it was already mentioned above I believe.
The stock ECU will adjust for the intake and exhaust mods, you should not be running lean.
All of the above indicates to me that your tuner was not having a good day, or you maybe misunderstood what he told you.
In any case his dyno needs serious calibration/maintenance.
Don't get carried away by these anomalies, I would do my due diligence before using this dyno for further assessment of mods, it will obvoiusly mislead you.
Old May 26, 2006 | 01:33 AM
FineProperty's Avatar
FineProperty is infamous around these parts
Originally Posted by wross996TT
HP is altitude adjusted (SAE)
I think this is where your error is, the CU avatar puts you in Denver, altitude adjusting for 4-5000 feet of altitude. You don't get to make that adjustment in a turbo, it makes it's own altitude. So, knock off the 3%x4.5 ish, puts you about 406 hp.
