Warm start problems
Old May 25, 2006 | 08:00 PM
ExTex50's Avatar
ExTex50 is infamous around these parts
Warm start problems
'03 X50 with about 10K miles. The car starts with no problems after sitting overnight. After the car is driven for a bit and is warm, it has problems starting up again. For example, if I drive to lunch and the car sits for only an hour or so, it's hard to start up again.
The battery/starter turn the motor ok, but it just has a hard time catching. Sometimes it won't catch at all, sometimes it will barely catch and run at about 300rpms until I give it some gas and then it sputters and comes to life. Once it fully catches, it runs fine and doesn't stumble at all on acceleration. Stock ECU at this point. Any ideas? Should I replace the plugs? I don't know what it has in there now, but it would be whatever was stock on an '03 X50.
I'm on my second dealer visit for this problem and two separate dealers have said they can't find any problems.
Mark
Old May 25, 2006 | 08:33 PM
tom kerr's Avatar
was the MAF ever cleaned or replaced? Check the codes?
Old May 25, 2006 | 08:40 PM
ExTex50's Avatar
The dealer checked the codes and found nothing. MAF has never been cleaned or replaced.
Old May 26, 2006 | 09:30 AM
t2_996420's Avatar
t2_996420 is infamous around these partst2_996420 is infamous around these parts
I just had a vacuum hose replaced but my symptoms were rough idle after sitting - once it warmed up it was fine. Have the dealer pressurize the intake and try to find a leaking hose. Other thing would be to check your fuel filter. Good luck.
Mark @ AIM Performance
Sep 22, 2015 09:17 AM
ritchrwi
Aug 29, 2015 08:27 PM
gulf gt
Aug 27, 2015 10:27 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
