Installing new turbos.
Originally Posted by M3CAB
So now my question is, I currently have a stock GIAC II programming with my stock K16's. Since these new turbos are K16/24, will the programming match to the K16 side of the turbo? I know it may not be a perfect program for these, but it should work. Quote from Sharky....."within reason the ECU adapts etc.. and it takes a lot for the car to actually run like **** so to speak".
Jag
Originally Posted by jags911tt
If I was you I would get the stage 3/4 software that is a very good match for Kevins stage 2's. Also add headers or port and polish yours (will make a nice difference in spool up)
Jag
Jag
Originally Posted by MX RACER
M3CAB,
TPC does have a dyno give Tom a call over there I did all my before and after
dynos there.. Good luck with the project..
Originally Posted by TKDalumni
I'm running Stage II Giac, w/ my 16/24's
M3CAB,
It's a dynojet rear wheel you have to disconnect front drive shaft..
I would do the before and after though it's cool to see the actual gains..
Let me know how it goes.. We need to have a local get together..
M3CAB,
Thanks! If I disconnect the front drive shafts, do I get an accurate HP reading? Also agree about getting a get together going. Where in MD do you live?
M3CAB,
You will get rear wheel hp not all wheel hp but alot of people measure this
way. The main thing is you will see exactly how much you gain from the changes you made.. I live south of Annapolis.. Where do you live??
have kevins turbos giac we played with the programs for a couple of hrs. can't remember stage we talke to giac told them what i was running and emailed the correct program.they are very responcive almost no lag....the use air give them as much as you can afford the trick in air in air out....you will love them''''
kevin suggest keeping your stock headers butttttt take a drummel to them. thats a job you can do at home no sweat. i elected to get s cargos laarger tubed headers to protect rod bending.........
I agree.. air flow.. air flow....
FVD intake plenum, kevins ported headers, air box, bigger ICs... these are a must....
2001 996TT 3.6L and stock ECU
