Removing the rear bumper
Old Jun 7, 2006 | 01:31 PM
WyattTT's Avatar
WyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud of
I know there was a thread on how to remove the rear bumper, but now I cant find it. Does anybody have a link to the thread? Or how about the steps in removing it?
Thanks in advance
Old Jun 7, 2006 | 06:29 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Open the trunk and remove the lights and the metal strip. Take off the wheels and remove the torque screws that hold the wheel well liner to the bumper. Under the bumper there is a series of torque screws, take them out.
Finally, open the flap on the bumperrettes and loosen the hex bolts inside them. Done
Old Jun 7, 2006 | 06:37 PM
WyattTT's Avatar
Thank you thank you thank you
Old Jun 7, 2006 | 06:40 PM
jags911tt's Avatar
No problem, I felt bad that no one had replied.
Old Jun 7, 2006 | 07:37 PM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
Thanks for the quick DIY write-up Jags! I was gonna post up a thread asking about how to remove the rear bumper too, but Wyatt beat me to it.
Old Jun 7, 2006 | 08:53 PM
jags911tt's Avatar
Welcome guys
Old Jun 7, 2006 | 11:29 PM
WyattTT's Avatar
I definately wasnt feeling the love!
Old Jun 8, 2006 | 01:49 PM
iaAaron's Avatar
Awaiting Email Confirmation
iaAaron is infamous around these parts
Tree stump, Rope, and a heavy pedal Just kidding. Good tips One other thing you will need to remove the bumperetts. there is a 6 or 8 MM hex bolt if you come in through the bottom. Loosen that a bit and the should be able to be pulled off.
Old Dec 24, 2008 | 04:41 AM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
The rear wheels have to come off to remove the bumper ??
Old Dec 24, 2008 | 08:57 AM
DaveMo's Avatar
DaveMo is infamous around these partsDaveMo is infamous around these parts
Go over to Renntech.org and do a search over there. You will find detailed instructions for this...and lots of techie questions...
Old Dec 24, 2008 | 10:28 AM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
Once you separate the bumper from the car, don't go too far with the bumper without disconnecting the plug that supplies power to the License tag light. It is also a good idea to replace the tail lights with the 2 screws loosely fastened so there is no danger of banging the lights against the finish. It's all a pretty quick and easy one-man job.
Old Dec 24, 2008 | 10:52 AM
RCH's Avatar
RCH
tvm. my question is do I have to remove the rear wheels to take off the bumper as I need access the torx screws in the upper wheel arch lining (which is above the height of the bumper) or do I just need to undo the Hex nut half way up the wheel arch and the Torx screw at the base ???
Old Dec 25, 2008 | 11:33 AM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
You can actually take it off without removing the lights and wheels, very easy. Although Jags's way is correct.
Old Dec 26, 2008 | 08:11 AM
RCH's Avatar
RCH
ok art I am gonna try it your way tvm
Old Dec 26, 2008 | 09:31 AM
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
How do you do this Art?
Thanks,
Ryan
