dry sump?
Old Jun 12, 2006 | 06:16 PM
tony102385's Avatar
tony102385 is infamous around these parts
dry sump?
does the 03 996 turbo us a wet or dry sump oil system?
Old Jun 12, 2006 | 06:45 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
o1 does nnot dam
Old Jun 12, 2006 | 10:05 PM
PorschePhd's Avatar
All Twin turbo and GT3 cars use the dry sump system. It is the same as the 993/964 and so on. We were one of the first to build these motors so we have seen many of them and can also confirm the X50 uses the GT3R Oil pump.
Old Jun 13, 2006 | 01:03 AM
djantlive's Avatar
does the dry sump on tt require draining oil at a couple of places like 993? Or only 1 drain plug on the oil pan?
Old Jun 13, 2006 | 01:23 AM
tony102385's Avatar
dry vs wet is location of where oil is basically stored. so I believe only one place on tt for drain plug but I may be wrong.
Old Jun 13, 2006 | 01:31 AM
Benjamin Choi's Avatar
Benjamin Choi is infamous around these parts
Gt1 series baby
Old Jun 13, 2006 | 07:20 AM
PorschePhd's Avatar
There are 4 places to drain the oil, the oil tank, the case and the two drip tanks from the turbos.
Old Jun 13, 2006 | 09:19 AM
kiko's Avatar
kiko is infamous around these parts
Is there a DIY for changing the oil on the TT showing the 4 draining spots? I guess you should drain the oil when hot on those 4 places, change the oil filter and than just put 8qt of oil and start the engine? I really need thses directions as I'm changing the oil myself for a proper PAO ester synthetic as Motul 5W40 Power.
Old Jun 13, 2006 | 09:29 AM
PorschePhd's Avatar
Yes, do it when warm and start with 8 quarts. Bring up to temp and test the level. You do not want it FULL, rather a notch down from the full mark. Your oil choice is fine.
Old Jun 13, 2006 | 10:32 AM
Turbochris's Avatar
Turbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond repute
Why do we not want it full?
Chris
Old Jun 13, 2006 | 10:44 AM
PorschePhd's Avatar
They have a tendency to over pressurize the case and smoke more on startup not to mention expansion and the risk of pushing oil up to the MAF. Seen it several times. Dry sump is not critical to actual level as a normal setup. Oil is always moving across the system rather than sitting in the pan. This is something we have done for years on the older 911s. You would be surprised HOW LITTLE oil a 911 can run on.
I am not telling you guys thought because someone might try it
Old Jun 13, 2006 | 11:31 AM
kiko's Avatar
I found the DIY instructions on another Forum (known for this) and it had factory drawings but it doesn't show where to drain the turbos, can you give me a hand with a description of the location and wrench to be used?
Stephen thank you again for the help provided.
Old Jun 13, 2006 | 12:19 PM
PorschePhd's Avatar
Directly under the turbo there is a 8mm allen. This is the drain. There will be one for each turbo. Can't miss it. I will see if I can snap a pic for you.
TT Surgeon's Avatar
I know of one guy who took his TTcab to jiffylube to save a few bucks.They only drained one plug and filled it beyond capacity. Fried the turbos.
Old Jun 14, 2006 | 11:46 PM
tom kerr's Avatar
Stephan, I always have my oil drained at the dealership. Is it their protocol to drain at all four places??? Great info thanks, just made my OCD worse!!
