Is using sea-level correction factors for TC cars incorrect?
Old Jun 20, 2006 | 11:01 AM
Divexxtreme's Avatar
I've seen people use them on this forum when discussing 1/4 mile runs, and it always struck me as odd.
What I have always assumed, was:
1. Since turbocharged vehicles (specifically a modded Porsche TT) continue to produce boost until their TCs are maxed out, or until their wastegates open to reduce/maintain the boost level (a preset of 1.3 bar for example)...it stands to reason that a TC car should have the pretty much the same power at any reasonable altitude that it does at sea-level. Or very close to it. Is this not correct?
2. A SC car has a preset amount of boost, based on pulley size and engine rpm...so at altitude, it won't have as much power that it would at sea-level since the pulley size/max engine speed is fixed.
3. And of course, a N/A car will never have as much power at altitude as it does at sea-level.
If 1. is correct, than wouldn't using standard sea-level correction factors for a TC car's 1/4 mile run produce highly innacurate results?
Thanks.
Old Jun 20, 2006 | 11:07 AM
Scott. some of the fastest 1/4 times have been done at some of the highest altitudes... and this is according to my evo8 tuner who makes 8 second cars on a 2 liter motor all day long. He knows his SH$t.
Im not going to comment because Im no pro at this...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 20, 2006 | 02:14 PM
rwm514's Avatar
rwm514 is infamous around these partsrwm514 is infamous around these parts
Ive wondered the same thing for years. Ive posed the same question to some "experts" and no one can really give me a straight answer. From what Ive gathered, TC cars do lose some power as altitude rises but not as much as NA cars. I would really like to know as I live at 7000 feet!
Old Jun 20, 2006 | 02:20 PM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
Denver, huh? In Vegas, we are about at 3,000 feet.
Old Jun 20, 2006 | 02:33 PM
rwm514's Avatar
No, flagstaff arizona.
Old Jun 20, 2006 | 02:39 PM
dgussin1's Avatar
dgussin1 is infamous around these parts
This is a quote from the same topic from a Cobra Turbo forum...http://www.modularfords.com/forums/r...rbo-54099.html
OK...perhaps a compromise then. I decided to do it this way. I posted the derivation of the SAE J1349 correction factor here:
http://www.modularfords.com/forums/2...ion-54094.html
Introduction
Most everyone is familiar with the usual SAE (or STD) dyno correction factor, which are used to scale the measured power and torque to what would be measured at some reference set of ambient (weather) conditions. (For SAE J1349, these are: absolute ambient air pressure of Pref = 990 mb, ambient temp of Tf = 77 °F, and RH = 0%.) These correction factors were developed for naturally-aspired engines wherein the intake manifold pressure goes in direct proportion to the ambient pressure. (See link to the derivation given above.) Therefore, the scaling factor (αp) for indicated power with pressure has the inverse relationship and goes simply as
αp = Pref/Pdry
where Pdry is the dry-air partial pressure at the time of the measurement and Pref is the reference air pressure. Since it can be shown that the boost pressure (and hence the total intake manifold pressure) for an engine with a P-D supercharger is also directly proportional to ambient pressure, these correction factors still apply for these cases as well, at least to first order. (It will not correct for changes in the parasitic drive power of the SC as air density goes up and down, for example.)
For a turbocharged engine, however, this is not the case. Since these setups typically employ boost controllers that are designed to keep boost pressure constant, the total intake manifold pressure is less affected by changes in ambient pressure. (It is still affected since the intake manifold pressure is the sum of ambient plus boost pressure, but to a lesser amount.) As a result, turbocharged engines don’t gain or lose much power as the atmospheric pressure changes up or down. Therefore, the standard SAE J1349 type correction factors are wholly inappropriate for turbocharged applications. Below is a description of how pressure would scale for a typical turbocharged engine with boost controls to keep boost constant.
Turbo correction factor
Skipping all the math, (if someone really wants to see it let me know), for a turbocharged engine with a constant boost pressure, (after the turbos are fully spooled), it can be shown that the indicated power and torque would scale with pressure as
αp = (Pref + Pb)/[Pdry(1 + Pb/Patm)]
where Pref is the reference dry-air absolute pressure (29.235 in-Hg for SAE), Pb is the boost pressure also in in-Hg (= 2.036*PSI), Pdry is the absolute dry-air partial pressure at the time of the measurement, and Patm is the total absolute air pressure at the time of the measurement. To get the brake power scaling, clearly the mechanical efficiency needs to be factored in here as well. (See that other thread).
Below is a table showing how the two correction factors might differ for a turbocharged engine measured at a mile high with everything else at SAE J1349 conditions; Pref = 29.235 in-Hg, RH=0%, etc. There are other assumptions that I'll not get into here. Note how the “typical†correction factor overestimates the results and gets increasingly worse at higher boost pressures. It should also be pointed out that the difference between the two will change as the other conditions change. For example, as the absolute ambient pressure approaches the reference pressure, the difference is reduced.
For the above conditions, the SAE J1349 correction factor is: CFsae = 1.254
First column = boost pressure in psi
Second column = boost pressin in in-Hg
Third column = dyno CF appropriate for a turbocharged engine (CFturbo)
The 4th column shows how much the SAE J1349 CF overcorrects the results (relatively speaking), i.e., 100%(CFsae/CFturbo - 1)
Code:
Pb    Pb
(psi)    (in-Hg)    CFturbo    sae/trbo-1
5.0    10.18    1.178    6.40%
7.5    15.27    1.155    8.53%
10.0    20.36    1.137    10.22%
12.5    25.45    1.123    11.61%
15.0    30.54    1.112    12.76%
17.5    35.63    1.102    13.74%
20.0    40.72    1.094    14.57%
22.5    45.81    1.087    15.30%
25.0    50.9    1.081    15.93%
27.5    55.99    1.076    16.49%
30.0    61.08    1.072    16.98%
Old Jun 20, 2006 | 03:26 PM
rwm514's Avatar
Whoa. Kinda lost me there. Im guessing that means at 20psi boost we lose 14.57% bhp? Can anyone clarify?
Old Jun 20, 2006 | 03:42 PM
Got it. I found some other articles online as well.
It looks like altitude effects S/C cars and N/A cars almost equally. But it hardly effects TC cars at all.
So, in summary...when dealing with a TC car, in order to remain accurate....you shouldn't use altitude correction formulas when comparing drag times, and you also shouldn't use SAE correction on dynos.
.......the percentage of power loss between a naturally aspirated engine and a mechanically supercharged engine is close enough to be considered the same. This is what SAE corrections on dyno’s is designed to compensate for. They are basing the results at a certain altitude (and temperature but it won’t be discussed here) and try to get their results back to sea level on a perfect day. This is a set standard and makes numbers from other dyno’s easy to compare. This correction value is based on a set % for altitude and temperature. This is fine for naturally aspirated of mechanically supercharged vehicles but is worthless for exhaust driven turbocharged vehicles. This is because mechanically driven superchargers are boosting to a certain set ratio of air greater than what the engine is actually sucking in. An exhaust driven turbocharged vehicle is set to reference pressure to sea level. At higher altitudes it just works harder to get that pressure back up. It has to work harder since there is less pressure to start with........The total gain is different and calibrated to a fixed, known location. This is why you use SAE corrections for naturally aspirated and mechanically supercharged engines but not for exhaust driven turbocharged engines. SAE correction factors for turbocharged vehicles will basically be the same as giving you some free boost. That's cheating the numbers. It may be great way to sell more product but it isn't an accurate representation of how much power you put down. The greater the altitude change, the more inaccurate it becomes.
In reality, there are some differences that offset the effect of turbochargers holding boost at higher altitudes. First off, the turbo is working harder since it has to spin faster. This creates more heat. we also have an average loss in temperature of 3 degrees F over every thousand feet in elevation rise. While these will affect the final numbers from sea level a small amount, they are nowhere near as off as the SAE correction factor for turbocharged engines at altitude. The other thing to consider is that your turbo may get well out of it's efficiency range at these speeds. Different turbos will have different results so you can not have a set standard.
The next time someone tells you that you need to use SAE correction for a turbocharged engine because it is the "standard", laugh at them, tell them to go do their homework and to just go ahead and print up your uncorrected dyno sheet (turbo cars) so you can leave.
Old Jun 20, 2006 | 04:22 PM
wow... and I did 640 hp to all 4 wheels on my evo8 SAE corrected.
Im at 600 ft. above sea level.
9.66
click to view
PorscheEnthusiast
Nov 13, 2015 02:23 PM
r_matt_6
Oct 8, 2015 06:07 PM
TrackOne
Aug 20, 2015 12:56 PM
