Final Wheel Spacer Question :(
Old Jun 26, 2006 | 02:45 PM
  #31
JohnnyBeatles's Avatar
JohnnyBeatles is infamous around these parts
LOL now I really feel foolish....
JB
Old Jun 26, 2006 | 02:47 PM
  #32
iLLM3's Avatar
JB
LOL dont worry about it man, happens to everyone
Old Jun 26, 2006 | 03:28 PM
  #33
wross996TT's Avatar
OK I was wondering how in the world you were going to do that combination.
Old Jun 26, 2006 | 04:51 PM
  #34
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Originally Posted by ari
Although I installed 15mm spacers in front already and have NO rubbing. None at all. I have driven the car hard in the canyon, turned lock to lock and even went up a steep driveway at an angle to compress the suspention. So Far so good. The rears are next! I am not expecting any surprises.
The car is lowered using FVD PSS9s and is using an X73? (something like that) suspention alignment.
I wonder if a GT2 alignment would work? Not sure of the car has enough adjustment built in for that.
Pictures worth a couple of words ........here's an old pic of 14mm all around on hollows (painted) i.e. 36 / 31mm F/R offset...car was set to bottom of Euro (X73) specs.....relatively low.
Old Jun 26, 2006 | 05:45 PM
  #35
Turbo Fanatic's Avatar
Originally Posted by wross996TT
ARI, I asssume you mean suspension settings (vs. Alignment). Do not use the GT2 Height settings with the PSS9s as you may hit the bump stops...this is very bad for handling. You will love the FVD version (I have them myself!)
I've had the PSS9s for a few months. I do love them. It's amazing once you try PSS9s to think that Porsche actually sold the TT with the stock suspention. Mine are not set as low as a GT2.
The question I was asking is will a GT2 specification alignment work on a TT? Does the stock TT have enough adjustment for a GT2 spec alignment. I currently have an X73 spec alignment.
GreggT: did you rub the front lip less often with the C4s lip installed (in the picture)?
Old Jun 26, 2006 | 05:56 PM
  #36
iLLM3's Avatar
i would imagine you can do the same exact alignment spec as the GT2, even more aggressive with fully adjustable aftermarket coilovers, probably swaybars as well!
Old Jun 27, 2006 | 12:15 PM
  #37
GreggT's Avatar
Ari......yep on the C4S chin spoiler.
There are many, many things you can do with a Turbo front.....I was not going for bling here, clearance was high priority (along with understated & clean.......some call 'boring').
Here's another pic with other wheels (sorry, this has been posted many times). Front clearance at the left & right lip corner is about 8cm.....I originally had it at 7.28 but took it up a tad.
Per the GT2 specs......only comment I'd have would be that they are a tad different (the specs).....the rear height range 133-143 can not really be compared to U.S, ROW, X73, or GT3 specs cause they use a dif measure point on the rear GT2 & not the regular flat spot on the rear sub-frame (someone correct me if I'm remembering wrong here.
Again, if you want to take it down significantly, you need an adjustable system that accomodates that well (& still performs). Just my opin but I'd also say that sysstem should include adjustable sways with adjustable DLs to give you full ability to corner balance at whatever rake & height you're shooting for........be it GT3, X73, or whatever.
Good luck!
Old Jun 27, 2006 | 08:38 PM
  #38
OK. More answers than questions at this point.
I fit 15mm all around. The diffrence in apearance is very dramatic!
More to the point, the car really seems to handle much better. Seems more stable. I really didn't expect a performance improvement... maybe it's in my head?
Would you feel a 30mm total increase in track?
Old Jun 27, 2006 | 08:40 PM
  #39
iLLM3's Avatar
Definitely is a bit more stable and handles better which is contributed by the spacers...
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
