Best Mod
Old Jun 25, 2006 | 11:10 AM
95RogueM3's Avatar
95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of
Originally Posted by Ken
IMHO, a Kreis Seig exhaust is probably the best sound and gives you the ability to switch to straight pipes by simply pushing a button.
So would an exhaust cutout, but at an extreme fraction of the price. www.quicktimeperformance.com makes some fantastic valves.
Old Jun 25, 2006 | 05:05 PM
iLLM3's Avatar
I love exhaust cutouts, think its an amazing mod. Have it loud with some actual exhaust note wide open and max gains, or quiet exhaust. I was going to do that to my turbo, but from the heat the valves seize up, happened to 2 turbo's that my shop did!
Old Jun 26, 2006 | 12:34 AM
95RogueM3's Avatar
It depends upon the quality of the valve. I have personally seen a Kreis-Seig valve (vacuum operated, of course) seize up as a result of heat, but the owner of QTP claims he hasnt yet had that happen to one of his valves; I think a valves life-span is dependent upon materials used and clearancing between the butterfly and the surrounding shroud.
Old Jun 26, 2006 | 12:40 AM
iLLM3's Avatar
Hmm interesting! I might give it a try, my shop would do it for cheap since im a sponsored car, they just said the valves on the turbo's they've done seized up because of all of the heat, i'll ask them which valves they used! Thanks.
Old Jun 26, 2006 | 10:24 PM
Shark01's Avatar
Shark01 is just really niceShark01 is just really niceShark01 is just really niceShark01 is just really nice
I'm going to call those QTP guys, thats one hell of an idea they have
Old Jun 26, 2006 | 10:34 PM
95RogueM3's Avatar
They do have some quality products. They are local to me, so I even went and saw some installs they have on shop cars (Camaro, WRX, Silverado, etc)...all seemed to be working flawlessly.
I would probably just buy a valve (not the valve attached to the piping) for a 996 application and then have a local exhaust/custom shop install the valve with a piece of stainless. From what I have seen is involved in the install (on E46 M3s in particular) the shops shouldnt charge more than $35-$50 for the piping and welding. Best of luck.
Old Jun 27, 2006 | 02:14 AM
iLLM3's Avatar
WTF, my shop said it was like 800-1000 to do it for most people, not me but still
Old Jun 27, 2006 | 12:22 PM
95RogueM3's Avatar
YIKES! On the M3s I have seen them installed on the valve was simply welded on to the section 2 pipe (pipe directly before the muffler) in a matter of minutes. This cost, of course, didnt include running the wires up into the cockpit to the momentary switch for opening and closing the valve, but thats easily done in an hour or so in your driveway. (or if you wanted to pay, Im sure a stereo shop could do the wiring for it in an hour or so)
For a 996, you would need 2 valves (for both banks) which would be $250, + the module they sell to tie the two valves together so they would open at the same time via one switch, + install.
Maybe my estimate was a bit low...but any more than $500 for a completely installed and wired system would be taking it in the shorts.
Old Jun 27, 2006 | 12:26 PM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
I now say that the RWD conversion is probably the best bank for the buck mod out there...
Old Jun 27, 2006 | 12:49 PM
iLLM3's Avatar
Yea 500-600 sounds like a good deal or estimate! I think the valves they were using were like 250 or so a piece, that's probably why!
Old Nov 24, 2006 | 01:30 PM
cpu77's Avatar
cpu77 is infamous around these parts
Is there a vaccum relay available so everytime you hit boost it opens the electronic cutouts?
Old Jan 9, 2008 | 10:02 PM
Gary in BR's Avatar
Gary in BR is infamous around these parts
ATP makes one but it has been on back order for a few months
Old Jan 10, 2008 | 12:41 AM
Zippy's Avatar
Originally Posted by ritchieswimwear
...Is there another mod that gives you the jump like the ECU flash, or is it small steps that add up in HP increase?
Sway bars, Coil overs, Wider GT2 size wheels and some FAT RA1 Racing compound rubber will give you a bigger "jump" than your ECU Flash.
Old Jan 10, 2008 | 07:13 AM
930man's Avatar
930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future
going with gmgGT exhaust motons and bladed adjustable sway bars in rs uprights to start with
Old Jan 10, 2008 | 07:04 PM
tom kerr's Avatar
On a stage 2 car with an EVO intake, what is the next best mod where you would notice a big difference. The flash was easy to tell the power increase, but the exhaust (more for sound) and the intake increases are hard to tell. Is there another mod that gives you the jump like the ECU flash, or is it small steps that add up in HP increase?
there are many good upgrade suggestions above. depends on what YOU are looking for?? for your car the best thing to do is suspension upgrade.
but if you are looking for hp and torque you will need to upgrade turbos.
stilov
Sep 24, 2015 01:10 PM
ggf
Sep 17, 2015 11:40 AM
maroli
Sep 15, 2015 07:07 PM
