RWD Conversion Complete...one word...AWESOME!!!
Rating: Thread Rating: 2 votes, 5.00 average.
Old Jul 11, 2006 | 11:53 PM
  #136
iLLM3's Avatar
Originally Posted by MARKSKI
Hey you guys... I guess I will answer all ur questions soon.... If my rwd conversion blows up... ull be the first to know...
BTW- I have 1000 hp.
Showoff jk
Old Jul 11, 2006 | 11:58 PM
  #137
Martin,
actually I dont expect it to last... LOL
Alexanders' is holding up so we will see.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 12, 2006 | 12:00 AM
  #138
iLLM3's Avatar
Martin,
Very true, he is also still AWD though. I would imagine that would be even more strain, BUT going RWD is putting all of the stress on the non GT2 diff, who knows. Goodluck!
Old Jul 12, 2006 | 12:02 AM
  #139
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
Martin,
So you think you'll crack into the high-high 9s with your set-up? Polish power
Old Jul 12, 2006 | 12:03 AM
  #140
iLLM3's Avatar
Tell me your Polish also, can it get any more ironic
Old Jul 12, 2006 | 03:34 AM
  #141
Thats some funny sh@t.... yes he is...
we will see...9s .. hmmm. I hate to contemplate... cause it does no good and leaves u open to critism.. so when I do it Ill have the proof.
I first need some supper dupper axles...
9.66
click to view
Old Jul 12, 2006 | 11:35 AM
  #142
iLLM3's Avatar
Wow crazy Mark lol.. Anyway yea, just run it then shock the world!! No need to say what you think the car will do, it will be insane.
Old Jul 12, 2006 | 01:02 PM
  #143
Me_qwkr's Avatar
Me_qwkr is infamous around these parts
i know as hard as this was to believe the techart did for awhile.. I dont remember currently who owns it but there was a huge fight on this subject at my boys shop the other day and it was just about not if it was a 996tt but which turbo it was.
Old Jul 12, 2006 | 09:44 PM
  #144
Billystang's Avatar
Billystang is infamous around these parts
that sounds great i will talk to my mechanic tommorow!
Old Jul 13, 2006 | 12:24 PM
  #145
Turbochris's Avatar
Turbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond repute
WHOA! It got on the dyno? NICE! Big Congratulations, I can't wait to here how you like it when you get it on the street.......what a monster......
Chris
Old Jul 30, 2006 | 09:12 AM
  #146
Billystang's Avatar
We need DIY and pictures for RWD conversion
Old Aug 22, 2006 | 12:04 PM
  #147
tradin1's Avatar
tradin1 is a splendid one to beholdtradin1 is a splendid one to beholdtradin1 is a splendid one to beholdtradin1 is a splendid one to beholdtradin1 is a splendid one to beholdtradin1 is a splendid one to beholdtradin1 is a splendid one to behold
where are the promised pics???
Old Aug 24, 2006 | 05:47 AM
  #148
Alexcwt's Avatar
Alexcwt is infamous around these parts
Originally Posted by Mz3bo
My tech advisor at the dealer told me the TT is equipped with "viscous coupler" or something like that and that by doing the RWD conversion, it will burn it in a short period of time....
Your Tech is right and wrong. The Viscous Coupling is what diverts torque to the front and the rear. It's not the one between the 2 rear wheels. It works kind of like a torque converter. Here is how it works.
http://auto.howstuffworks.com/differential9.htm
With that said, if the front is disconected, the fluid is always trying to transfer 40% (it's variable of 5% to 40% max) of the torque to the front diff that's not there. At the same time, the output shaft will catch up to the rear really quickly as there is no resistance to go the other way. So, yes, it will be working harder as every time there is output shaft speed change, the coupling will be working. But it's job is also a lot easier as there is no rotating weight and road force to deal with. I doubt it will burn it up.
To our luck, the Porsche Engineer has put this viscous clutch (part #6) in the front with the front axle. So it's an none issue as it will be removed by this conversion also.
Old Aug 24, 2006 | 06:20 AM
  #149
kiko's Avatar
kiko is infamous around these parts
Yep! Your tech is wrong and is the live example of the new generation of techs which know how to change parts but don't know why they're replacing them in the first place let alone knowing how their work. This one of the reasons why car manufacturers are calling the engines and gearboxes back to factory to rebuild them.
P.S. There are other issues with 2WD but the VC is not one them and there are fellow 6speeders with over 800bhp Turbos running 2WD.
Old Aug 24, 2006 | 08:23 AM
  #150
ColorChange's Avatar
ColorChange is infamous around these parts
Originally Posted by ari
Exactly my sentiment. We have confirmed that the X50 shares the same exact engine and transmission (minus the front drive) with the GT2. The only diffrence is that the GT2 has a cover plate over the front drive output. It's therefore not bad for your transmission at all to drive in RWD only mode.
BTW, I was recently reading that Porsche has programmed the 997TT to cut power to the front wheels during braking for more stability. I'm sure the 996TT benefits in this regard with the AWD disengaged.
The 996TT's viscous cenmter diffrential sends 5% of the torque to the front wheels. Disconnecting the front driveshaft frees up that 5%, removes a lot of rotating mass from the overall drivetrain and gives the car better steering feel.
If you are OK with the extra 125 to 150 punds of front end weight all you need to do is disconnect the front driveshaft. Talk about reversible...
ArI: I think you're a little confused here. When you are braking, there is no power going to the front wheels (your foot is on the brake, not the gas) so there is "no power to cut".
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
