Dyno graphs, stage 2. Help me analyze them
Old Jun 25, 2006 | 07:01 PM
rwm514's Avatar
rwm514 is infamous around these partsrwm514 is infamous around these parts
Originally Posted by ari
1 Bar = 14.7 Psi
19 Psi = ~1.3 Bar
Stock K16s can not mainatin 1.3 all the way to redline...
Here is my K24 Graph in RWD: http://members.dslextreme.com/users/...11%20Turbo.jpg
But apparently mine are holding at 19psi.
Old Jun 25, 2006 | 07:02 PM
Divexxtreme's Avatar
Originally Posted by rwm514
I trapped 121mph my very first day ever drag racing, bumping off the rev limiter, psm on and kicking in all thru 1st gear. Down at the scottsdale exotic car club day at the drags. Im a crappy drag racer
Im not sure if it would have been better with a good launch though.
A better launch wouldn't have helped as much as not hitting your rev limiter.
Old Jun 25, 2006 | 07:05 PM
evsmotors's Avatar
evsmotors has a spectacular aura aboutevsmotors has a spectacular aura about
Whats up with the Dyno curves? Seriously wierd horsepower output! It goes up and way down and back up. You need to have it tuned again. I think your Turbo is trying to draw boobies on the dyno graph!
Old Jun 25, 2006 | 07:46 PM
rwm514's Avatar
Thats funny, It does look weird. Does anyone know whats going on with that??
rwm514's Avatar
What kinda power does a trap of 121 come out to?
Old Jun 25, 2006 | 07:56 PM
evsmotors's Avatar
Not sure about your mods nor do I have experience with a 996 Turbo. However I have seen similar problems with other turbocharged cars. The turbos may be pushing the limits and the a/f or timing may be off. The car could be pulling timing when it sees too much boost or some knocking, the reason for the dip. Once the timing is pulled the cars goes back to normal and power goes back up but takes a plunge again when timing is pulled.
Old Jun 25, 2006 | 07:58 PM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
Here is my Dyno with about same mods: evo stage 2, V-flow, DV, Ruf exhaust. This was done by Dyno Dynamic and with no fans point to intercooler. So the number is really low. Your number is about right from 2 wheels dyno, But just compare the shape of the graph with mine, EVO site graph and yours. Your HP and TQ drop a lot after 5K??
Old Jun 25, 2006 | 08:03 PM
wross996TT's Avatar
Yeah, I just looked at mine and I do not have the camel-back hump (boobie curve as referred to earlier) in the HP and mine does not die st 5K rpm...think maybe some fine tuning to the program is in order.
Old Jun 25, 2006 | 08:07 PM
Evolution MotorSports's Avatar
Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !
I have the dyno from when my car was just tuned by EVOMS. At the same time, a stage 1 clutch was installed, evo intake, fabspeed exhaust, and ROW suspension. What do you guys think? I'm seeing 448 rwp and 477 rwt. The front drive train was disconnected for the dyno. The tuner said the car should show more power after a while (it was dynoed immediately after the mods). I regularly see 1.2 bar and occasionally 1.3 bar on my boost gauge . The car seems really fast.
BTW, the dyno says "flywheel hp" but i was told it should say "wheel hp"
19PSI is not correct. Did someone adjust the wastegates? The ECU is only calibrated to run 1.0 - 1.1 bar MAX. The dip in TQ and HP is most likely due to an over boost. The power will most likely stay the same at 1.0 bar as the turbos become inefficient much past that and generate too much heat thus causing a dip in power. Let me know
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
wross996TT's Avatar
That makes much sense Todd...thanks for the response!
Old Jun 25, 2006 | 08:30 PM
Turbo Fanatic's Avatar
There is defintely SOMETHING happeing at 4800 RPM. Either overboost, or maybe the computer is falling into limp mode (not enough cooling on the dyno)?
The shape of my graph looks pretty similar to EVO's.
Old Jun 25, 2006 | 08:36 PM
evsmotors's Avatar
Yes, what he said. I was close enough.
Old Jun 25, 2006 | 08:47 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
hey guys have not been on a dyno after switching to giac hear are my mods any idea as to rear hp ? europipe stg 2 loud scargo lg tube headers, kevins k16s giac to match new plugs (not the orig) evo air box, am thinking that about it... opps gt2 intercoolers.
Old Jun 25, 2006 | 09:06 PM
iLLM3's Avatar
Exactly! I felt my turbo's were being overworked with straight pipe's and the v flow, almost going up to 1.2 bar sometimes, felt like the throttle response and power just cut off, realized that it was way too much on the stockers!
Took the straight pipes off, steady .9-1.0 sometimes and it felt 100x different!!
Old Jun 25, 2006 | 09:42 PM
rwm514's Avatar
Thx for posting Todd. I dont think the wastegates were adjusted. The work and dyno was done in Connecticut at a place called "The Shop". The ecu was shipped to evoms. I will be bringing it in soon .
