Engine won't turn over??
Old Jul 8, 2006 | 11:43 PM
Zippy's Avatar
A couple of times this week, I got in the car, depressed the clutch to the floor and turned they key.... and nothing happened! Light working fine, radio too but the engine wouldn't turn an inch. I would pump the clutch a couple of times and the starter would finally decide to spark her up. WEIRD! Any idea what the hell this is all about???
Mike
Old Jul 9, 2006 | 01:36 AM
GT3 Chuck's Avatar
Administrator
there is a starter cutoff switch on the clutch...your's could be getting bad or perhaps the floormat or pedal (do you have aftermarket pedals?) is keeping the clutch from reaching the floor and closing the switch so the starter will engage...check the pedal travel and mat and if not those get the switch checked...could also possibly be the ignition switch but most likely the clutch..
Old Jul 9, 2006 | 01:50 AM
Zippy's Avatar
Chuck - you're right, it definately feels like the clutch switch is not being activated. That thing triggers about 1" from the floor, doesn't it? I can hear the slight 'clicking noise' at about that distance. I had the pedal mashed to the floor and had no response. Perhaps the switch is going. Stock pedals and carpet is in place. Thanks.
Old Jul 9, 2006 | 12:57 PM
Cody_1's Avatar
Senior Member
Cody_1 is infamous around these parts
I had the same problem. My stock floor mat was in the wrong place and didn't allow that extra 1/8" of travel for the clutch.
- Rich
Old Jul 9, 2006 | 12:59 PM
Zippy's Avatar
- Rich
I'll have a peak at that pesky thing and see...
Hope that's all it is.
Old Jul 9, 2006 | 05:06 PM
PorschePhd's Avatar
Simply check the bolt that is in it. They will back off every now and then and not allow full reach from the pedal. You can see it up in there. It is a small contact switch with an arm on it.
Old Jul 9, 2006 | 06:37 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
check your floor mat it's prob blocking your clutch travel
Old Jul 9, 2006 | 10:28 PM
Zippy's Avatar
Thanks Stephen. I had a look and saw a few things that you may have been talking about. 1) There was a brass bolt which mounted a piston that moved towards the front of the car. It looked fine. 2) there was a brass bolt/cotter pin thing a little higher up that seemed to be fine also. I'm not sure if either of these were the contact switch / arm piece you were referring to.
Jul 29, 2019 11:13 AM
Vicelord
Ferrari
17
Jan 26, 2017 12:50 AM
turbotuner20v
Sep 11, 2015 12:02 PM
