Cold startup, Black Smoke?
Old Jul 14, 2006 | 04:06 PM
scotty slc's Avatar
scotty slc is infamous around these parts
Just a quick question..... Are some of you modded turbo's noticing black smoke upon cold start up?
-Scott
Old Jul 14, 2006 | 08:18 PM
wross996TT's Avatar
No...Not here! Some white...I can't remember...someone has got to know....I think white is oil and black is coolant...but like I said I can't remember.
Old Jul 14, 2006 | 11:23 PM
willcoxmd's Avatar
willcoxmd is infamous around these partswillcoxmd is infamous around these parts
my car usually coughs up some smoke in the morning. Although, usually not black. I thought all 911's blow a little smoke at cold start up?
Old Jul 15, 2006 | 12:35 AM
LUISGT3's Avatar
I get some white every morining (in the hot *** AZ garage). Is that normal
Old Jul 15, 2006 | 12:44 AM
ebaker's Avatar
ebaker is infamous around these parts
It's probably running overly rich when cold.
Old Jul 15, 2006 | 02:46 AM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
mine have white smoke. If your have black smoke, you better check it up.
Old Jul 15, 2006 | 09:06 AM
scotty slc's Avatar
Thanks for the responces.... It puffs a bit of black smoke, It looks and smeels like unburnt fuel. I was just wondering if anyone else has this happen to them.
Im guessing:
Blue smoke = Oil
White Smoke = Coolant, (most cases Steam)
Black = Unburnt Fuel ???
Old Jul 15, 2006 | 10:30 PM
Turbochris's Avatar
Turbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond repute
A puff of smoke on startup is NOT uncommon......
Chris
Old Jul 16, 2006 | 01:41 AM
redbone's Avatar
redbone is infamous around these parts
Originally Posted by scotty slc
Blue smoke = Oil
Blue = oil
White = coolant (smoke, not steam)
Black/Grey = unburnt fuel
Most cars dump fuel on cold start to help heat the cats up faster, as the catalyst is only functional when hot. The white (light grey?) smoke is probably fuel as well.
If it billows thick white (think Santa's beard) smoke, you might suspect a seal.(are Porsche turbos oil/coolant cooled? I know nothing about Porsches )
Old Jul 16, 2006 | 02:16 AM
marvls's Avatar
marvls is infamous around these parts
Try to use your sniffer to help identify it.
Light grey = Unburned fuel. Smells like gasoline (like when you're filling up at the gas station). This is normal in the TT on cold start. Goes away quickly.
Thick white = Burning coolant. Thick acrid smoke with a burned sickly sweet smell. Usually happens if a head gasket is blown and coolant gets into the cylinder and is combusted. One of the "pleasures" of water cooled engines such as the 996. Idle is rough and the smoke doesn't go away.
Darker/blue = Burning oil. Smells like burning oil :-) Usually happens as the engine gets older and some of the lubricating oil gets around the seals into the cylinder and combusts. Think of an old clunker taxi cab's exhaust. Usually worse on start-up and heavy engine strain (eg accelerating).
Hope this helps,
Marv
Old Jul 16, 2006 | 06:12 AM
Arnie's Avatar
Arnie is infamous around these parts
Did you just have an oil change? Maybe overfilled
Old Jul 16, 2006 | 10:25 AM
scotty slc's Avatar
Thanks for the info guys..... I did take the car to get checked out..... everything is fine, it was due to overfilling Im just happy all is well....
J9277655
Dec 28, 2015 11:01 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
