Wastgate springs How Much?
What should it cost to upgrade wastgate springs on a stock K16? I'm told that along with the ECU upgrade its a good idea. I'm sure it is but at what cost???
Any help...
JB
Any help...
JB
$300 to $400
2001 996TT 3.6L and stock ECU
Originally Posted by JohnnyBeatles
I don't know how much diff it should be alot. I'm told $650 to do the upgrade. Is it worth the money?
JB
JB
Originally Posted by LUIS95993
I was worth it to my buddy with an X50. I would try to find out from Evo or IA if the difference is as noticable with the k16's as it is with the 24's.
Basically in short, not worth it for K16's with tuning and every bolt on!
JB
JB
u will have a heck of a time setting them up on k16s... whast the use of putting 1 bar springs when k16s peak at 1 bar...
a 1 bar spring means that it opens the flap at one bar and not below... so u will run ur turbos to death. a k16 has a 5 psi spring...
I really think u need some sort of turbo that can handle the extra pressure...
I was looking into this a while back, and someone at Evo told me the upgraded wastegates were not really designed for the K16 turbos. These were specifically made for the K24 application. Again, that's what I was told.
U didnt waste them... u them in the future.... U can put them on the k16s... but just keep the thing at 1 to 1.1 bars.. it may be difficult to dial them in...
I had 6 months trial and error with the 1 bar and 1.2 bar springs...
ist very important that they are set up correctly.... especially the nuts on them... they have to be the same.. otherwise u will work one turbo harder then the other...
Oct 5, 2015 01:44 PM
MONKY LONDON
Sep 28, 2015 07:16 AM
