Is there something wrong with my boost?
Old Jul 26, 2006 | 02:29 PM
Alpha's Avatar
Alpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud of
I have an '01 996tt Tip, and I've been considering getting an ECU flash, so I've been trying to learn what I can. I recall reading somewhere that for the non-X50 996tt, I should see transient peak boost at 0.8 bar, and sustained boost at 0.6 bar (under load). So I set out to see what my peak boost is by going to manual mode in 4th gear on a 20% upgrade hill and going WOT at 45mph. I saw 1.0 bar for just a moment, then it went down to 0.8 bar until I slowed down (about 80mph). When I did the same thing in 5th gear, I saw 0.8 bar for a brief moment, then it went to 0.6 bar and stayed there. From what I understand, this doesn't seem right (the 1.0 bar).
The car runs fine, no CELs, no strange sounds. I bought it 10/05 as a CPO from a dealer in IL, and I believe it is completely stock (original FR5 spark plugs and stock DV's). It feels a bit "laggy" at low rpms, but I think it might just be the higher gearing of the 5-sp Tip. I don't feel the boost really come on until about 3,500-4,000 rpms.
So ... is this normal? Or does it sound like someting is not quite right, and what might it be? I would appreciate any help. Thanks.
Old Jul 26, 2006 | 07:16 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
any cels? try unhooking your batt. for 15min. then go for a ride. sounds like your in limp mode. you do need to get rid of those old dvs. this happened to me a while ago good luck. unhooked the bat and all is well
Old Jul 26, 2006 | 07:24 PM
Alpha's Avatar
Steve -- no CELs, and the car runs fine.
Old Jul 26, 2006 | 09:24 PM
iLLM3's Avatar
How many mile's are on the car, just wondering? BTW stock k16 turbo turbo's are suppose to sustain a .6-.7 peak boost, the higher boost you are seeing for a second in the higher gears are because your turbo's are really under heavy load making them work alot harder, its not a true or accurate reading. I would change the DV's if i were you just for the hell of it, see if it is more steady boost wise!
Goodluck, Martin.
Old Jul 26, 2006 | 10:06 PM
Alpha's Avatar
Martin -- Thanks for the reply. I'm glad to hear that you think the high boost is just a matter of transient high load (and not necessarily an indicator of something else wrong). I remember reading a thread a while back where someone was seeing abnormally high boost levels, and he turned out to have a vacuum hose leak or something like that. But he was hearing a strange "whooshing" sound, and everything seems fine with my car -- no strange sounds. New DVs are on my list of things to get -- I would like to also get an ECU flash after that. I have well below 30k miles, so I'm not due for new plugs yet, but I still have the FR5's and would need to replace them with FR6's before the ECU flash.
Old Jul 26, 2006 | 10:10 PM
iLLM3's Avatar
Hey man, no problem. I mean to me, i do believe you dont have a boost leak issue and its just from the turbo's working hard in a higher gear under load, which isnt a true measure of boost being produced like i said, a true measure would be what you sustain at in 3rd gear or 4th, on about a level surface!
Cant go wrong with the ecu flash and diverter valve's, i feel it is such a necessary upgrade for turbo's, you will love it. And doing fresh plugs is a smart idea, goodluck
Old Jul 27, 2006 | 12:28 AM
Get the fr6 Bosch plugs... dont go with the berus they sell at the dealer.
Dvs need to be changed if u upgrade the ecu...
k16s spike like any other turbo... so its not uncommon to see 1 bar spikes.... its what the sustained boost is what counts...
change ur oil every year... not every 30k like they say...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 27, 2006 | 11:05 AM
Alpha's Avatar
Marksi -- Thank you for the advice. I'll make sure to insist on Bosch plugs when the time comes. I'm due for the annual oil change 10/06. I'll stop worrying about it, and just enjoy the drive!
Old Jul 27, 2006 | 01:10 PM
iLLM3's Avatar
So wait wtf, the actual car oil is suppose to be changed every year, not like 3k miles? Damm i cant believe in the manual it says 30k, wow!!
Old Mar 19, 2007 | 06:32 PM
ze_shark's Avatar
ze_shark is just really niceze_shark is just really niceze_shark is just really niceze_shark is just really niceze_shark is just really nice
May sound stupid, but I just discovered yesterday that the on board computer included a boost indicator ? Wow, new toy.
Was surprised to see how it stays stuck at 0.0 in normal driving conditions. What kind of boost pressure should I see on a X50 at full load ?
Old Mar 19, 2007 | 09:30 PM
tom kerr's Avatar
ah, that did sound stupid!!
0.9 bar
spikes are common and remember the guage that this guy just found is not very accurate anyway.
YJosephTT
Mar 28, 2016 02:31 PM
Oct 2, 2015 02:23 PM
Boltons991qtr
Sep 20, 2015 06:57 PM
Greehn
Sep 16, 2015 04:45 PM
johnny.dangerous
Sep 11, 2015 02:39 PM
