Big Tires!
Old Aug 4, 2006 | 09:32 AM
tom kerr's Avatar
Question Big Tires!
My car is lowered (see pic) and signif neg camber and lives mostly at the track... Does anyone think RA-1 tires 335 on a 12 inch wheel (GT2) will fit??
Zippy seems to think so, so thought I'd ask around before I ruin a set of tires!
TIA
tom
Old Aug 4, 2006 | 09:42 AM
wross996TT's Avatar
Tom, no actual experience here, but I seem to recall reading that a couple of guys had rubbing with the 335s (mark included).
Old Aug 4, 2006 | 10:17 AM
Joe Weinstein's Avatar
And don't even consider rear tire options in isolation. You need to
ensure the actual rolling diameter of the fronts are as close as
possible to the rears. If you're on track this becomes even more
important and the tolerances are lower. You have to consult the
manufacturer's tire specs (revolutions per mile).
I know a GT2 that runs 335s in the rear, and I know they did suspension,
fender, and wheel well alterations to accomodate them. I also know of
996tt owners who tried running 315 tires and rubbed their fenderwell
linings down to shiney metal or daylight.
Joe
Old Aug 4, 2006 | 11:01 AM
RennTechV12's Avatar
RennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond repute
I ran the exact same setup on my 996TT and ended rubbing through the plastic fender shield and the rear left boost hose. The GT2 can accomodate a 12" wheel but the 996TT CANNOT! Save yourself the trouble I had and don't do it.
Old Aug 4, 2006 | 11:23 AM
tom kerr's Avatar
Ok guys, thanks for the input. My 315's are perfect so I'll just stick with them I guess!!!
Old Aug 4, 2006 | 12:42 PM
sharkster's Avatar
Heya bud that was with my goldie BBS... those were 2 generations ago and had the incorrect offset for clearance. The new ones work a-ok and we've got 3 people already with the new BBS 12 inch (with the correct offset) and 335 RA-1s a-ok. There is some _slight_ rubbing on the fender liner depending upon how low you are...
Old Aug 4, 2006 | 01:11 PM
I have a 12 inch wheel( cargraphics) and its also on a 19 inch tire... 315/25/19 to be exact. I also have pss9 suspension.
no problems at all.
I tried a 335 but had inner rubbing...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 4, 2006 | 02:46 PM
tom kerr's Avatar
thanks Mark, just looking for "a little more"!!!
Old Aug 4, 2006 | 06:45 PM
ebaker's Avatar
ebaker is infamous around these parts
Whats the offset needed?
Old Aug 4, 2006 | 07:08 PM
Zippy's Avatar
TIA
tom
I'll be ready with a heat gun, fender roller and spacers when those wheels/tires arrive
Anyone know where I can get a good deal on a fender roller?
Old Aug 4, 2006 | 07:33 PM
tom kerr's Avatar
Thanks Zip!!!!!
Old Apr 29, 2008 | 10:15 PM
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
no problems at all.
Mark
have you tried the 315/30/19?? Hossier new tire , do you think it will fit and better, not affect AWD?
Old Apr 29, 2008 | 10:35 PM
heavychevy's Avatar
Why do you want more tire Tom? It's not going to increase anything but sidewall flex and maybe drag. Contact patch will not be increased. I can understand the wider wheels, but bigger tires without compensating and adding a stiffer sidewalled tire wont help you much at all. And you'd probably have to go wide body or tub the inner wheel well to get those to fit.
Having trouble putting that 650 to the ground? You should probably step up in tires, or downforce or down in power.
Old Apr 30, 2008 | 10:50 AM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
What is the correct offset needed to fit a 12" wheel ? and the most extreme you can get with rolling fenders, would 45 - 50 work?
Old Apr 30, 2008 | 11:45 AM
tom kerr's Avatar
this is an old thread but since up again I have been running 335's on 12's with stock offset and some liner mods and the fender edge cut off with -2.7 camber.
