Gt2 tune up
Old Aug 7, 2006 | 10:00 PM
  #31
sy996tt's Avatar
sy996tt is infamous around these partssy996tt is infamous around these parts
Originally Posted by SMR
One thing i have been thinikig of i want to discuss also, i live here in Sweden and the climate and fuel is the same as in Germany, would in not be dangerus for me to run a Software uppgrade from Giac or something simular, isn't it better to run a FVD box or maybe a 9ff box that are made for the fuel and climate we have..?
I think in Arizona, we have some of the most brutal environments to be testing a car in.. with the heat, altitude.. etc.... i would assume you would be safe with any tuner that has cars that are proven in these extreme conditions... a lot of the major car companies have proving grounds in Arizona.... just my opinion...
Old Aug 8, 2006 | 05:14 AM
  #32
SMR's Avatar
SMR
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
Yes true
But if the tuner has to much ignition diled in for the fuel qulity we or you are using we are going to get detonation and that is not anything i want...That is why i was curius to here maybe from the FVD sponsor if there is a diffrence in the software beteween germany and USA
Old Aug 8, 2006 | 06:10 PM
  #33
SMR's Avatar
SMR
sad that not some sponsor would speak up, i know we have FVD here and EVO other also, im in the market for buying
Old Aug 8, 2006 | 07:04 PM
  #34
box was 98 RON. It ran fine here.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 8, 2006 | 07:12 PM
  #35
SMR's Avatar
SMR
So you think they use the same software..?
Old Aug 8, 2006 | 07:21 PM
  #36
Im pretty sure unless something changed- could have BTW.
I guess Evan at fvd USA can answer it...
9.66
click to view
Old Aug 8, 2006 | 07:24 PM
  #37
SMR's Avatar
SMR
I hope he will get in here then and give us the advice
Old Aug 8, 2006 | 10:34 PM
  #38
Neil@Orton's Avatar
Neil@Orton is infamous around these parts
The software will be the same.Its only the GT3 that is different and thats only the lamda delay.
Old Aug 9, 2006 | 10:50 AM
  #39
Evolution MotorSports's Avatar
Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !
We have different programs depending on the fuel available. Your 98 RON is like our 93/94 octane. We do have a program that will be based on that fuel. We do test all of these programs in the extreme heat conditions and the timing maps will vary depending on conditions. In your cold climate, the program is optimized for cold weather but will not over-advance the timing due to the opposite extreme conditions.
When we tune here in AZ in the extreme hot climate, we have to be careful that we are not testing on the lowest timing map in the ECU. If the temperatures are very hot, the ECU can retard timing to make the engine safe for the outside conditions. If you take that same car that was tested in the extreme hot conditions that was fine and transport that car to the extreme cold climate, the timing can advance and cause detonation and a lean condition.
We have monitored all of these changes and have corrected for them in the ECU calibration so that they are safe in all climates, conditions and fuel grade. Hope this helps.
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
Old Aug 9, 2006 | 11:24 AM
  #40
Evan333's Avatar
Evan333 is infamous around these parts
Sorry for the late response, I have been crazy busy and did not realize you wanted me to jump in!
FVD programs are normally done for 98RON (which in US terms is 93 octane). We have different programs for different areas, however the ECUs also adapt a bit also (so the difference between 91octane and 93 octane is not really enough to requre different programing unless the person wants to really get every little bit of power out of it).
SMR: Give FVD DE a call (0049-7665-98990) and explain what you are looking to do. They will get you set up with a box that will fit your exact specifications! If you have any more questions feel free to post or message me and I will do my best to answer.
Regards,
Evan
Old Aug 21, 2006 | 07:36 PM
  #41
SMR's Avatar
SMR
If i buy a FVD box, is it core exachange or to i get to keep my OEM ecu..?
Old Aug 22, 2006 | 05:20 AM
  #42
VRAlexander
Guest
Posts: n/a
Do not have the need for more then 525hp
Attachment 39986Y E SAttachment 39987
Old Aug 22, 2006 | 05:38 AM
  #43
SMR's Avatar
SMR
Originally Posted by VRAlexander
Not at the moment.., i have other cars when i need accleration..
Old Aug 22, 2006 | 10:09 AM
  #44
WOODTSTER's Avatar
Japanese Cars ???
MK
Old Aug 22, 2006 | 10:25 AM
  #45
SMR's Avatar
SMR
Originally Posted by WOODTSTER
Japanese Cars ???
MK
Yes..
I have some supras,skylines.A Drag car also and some other toys...The gt2 is "total packaged car"..
