Turbo S/ X50, does this sound right??
In another forum I can across this info from what seems to be a pretty knowledgeable guy...
"444bhp from 414bhp on non-S
457lb/ft from 413lb/ft on non-S
350mm ceramic brakes from 330mm steel brakes on non-S
They reworked the 3.6l engine significantly to get these gains, it isn't just a boost bar job. As a result the spread of tq is more even giving immediate in-gear push.
official 0-62 is 4.2 and top speed 191mph but they test quicker.
However, no match in a straightline for a Renntech SL600 ramped up to 675hp."
To which I asked, "how did they rework the engine?"
His response...
"They used larger compressors and turbines and enhanced the intercoolers. They also empolyed advanced cross-flow water cooling (developed for F1) which allocates a seperate circuit for each cylinder and head to help with engine cooling. Tq is an almost flat max line from 3000-5000rpm on the S/X50 variant of the engine."
Just wondering because Ive never heard of this "enhanced cooling". I would think the torque curve is similar in shape in the x50 cars just higher torque #'s and at higher rpms, ie 3500-5500 vs 3000 to 5000 for k-16's.
His response...
His response...
His response...
Originally Posted by PorscheC4
That sounds right on the money. I think the Turbo S had more boost and larger intercoolers and the GT2 has larger turbos and modified intercoolers. Both have modified ECU programming.
"They also empolyed advanced cross-flow water cooling (developed for F1) which allocates a seperate circuit for each cylinder and head to help with engine cooling"
I guess I dont consider bigger turbos and intercoolers "reworking the engine"
Originally Posted by Me_qwkr
Yo i own an S...this is the deal...Its a GT2 with AWD... plus the added weight.. its the exact same motor, and setup except for the awd...
Yes, but what about this...
This was posted earlier. I think this a comparison between a Gt2 and a standard turbo.
Intake air enters through hollow uprights of rear spoiler; ride height is 0.78 in. lower than Turbo's; vent in front of hood reduces front-end lift, improves cooling; underbody panels reduce lift and direct air toward transaxle; ceramic-composite brakes have spiral internal vents that increase surface area for better cooling.
- 2.7 psi more boost (from 11.8 psi to 14.5)
- larger intercoolers
- mufflers with less backpressure
- 6-speed transaxle w/steel synchros (vs. brass) for durability; limited-slip w/40-percent locking under acceleration, 60-percent under braking; external cooler
- firmer springs and shocks
- larger anti-roll bars (front diameter increases from 0.95 in. to 1.05 in.); rear bar is smaller (0.81 in. vs. 0.87 in.) but is 4-position adjustable
- metal bushings replace rubber in suspension links; uniball camber plates for upper strut pivots
- adjustable ride height with threaded spring perches
- wider wheels (8 1/2 & 12-in. widths f & r vs. 8 & 11)
- bigger tires (235/40ZR-18 & 315/30ZR-18 vs. 225/40ZR-18 & 295/30ZR-18)
- manually adjustable rear wing (1–6 degrees)
- deletion of driveshaft, viscous coupling, front differential, front halfshafts, four CV joints (est 150 lb)
- spare tire deletion (29.0 lb)
- ceramic-composite brake discs replace cast-iron units (36.6 lb)
- rear seat deletion (17.6 lb)
- misc.-power sunroof delete, cooling fan delete for third center-mounted radiator
rwm to answer your question..........the GT2 and S or X-50 is the same engine. it is the upgraded stock engine reprogramed with K-24 turbos and finned intercooler. It does run higher boost to 0.9. 9elevens post lists the further difference between the S/X-50 and the GT2.
Im not wondering the differences between the gt2 and x50, the thread is questioning the difference between the engines of the regular 996tt and the x50/ turbo S cars. A guy from mbworld claimed that the x-50 cars had a "reworked engine". I think what your is saying Tom K that they are the same engine, so what this guy from MBworld came up with is straight out of his a$$. Right?
