Lowering My Baby
Old Aug 29, 2006 | 08:13 PM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
i guess i'm defintely not getting the H&R put on then.. hehe
Old Aug 29, 2006 | 09:15 PM
wbvega's Avatar
wbvega is infamous around these parts
get something adjustable...it will make your life easier as time goes on. Motons, JIC/Cross, PSS9, Techart, etc. All will take the same amount of labor to install and leave you up/down and dampening adjustments external on the car. bottom line...springs are good for ballers on a budget, but not the best solution.
BL
Old Aug 29, 2006 | 10:56 PM
tom kerr's Avatar
I thought the poster asked the question re suspension lowering for under 1K? there are no other opinions other than the springs for that cost. of course the car will not handle correctly, but if just plain street driving it will still be "ok"
Old Aug 30, 2006 | 01:11 AM
wbvega's Avatar
youre right, he did...but like most of these threads...it wandered. I agree with your summation on handling and personally i dont think there are any options under $1K. With the cost of springs, add in labor and alignment, you exceed $1K already.
BL
Old Aug 30, 2006 | 08:41 AM
TAnthony's Avatar
TAnthony is infamous around these parts
Thanks for the responses. You guys certainly know your stuff.
I'm not looking for a suspension to track, just want to lower the car. Price isn't really the big factor so much as it is not screwing up the car. (I can go over $1,000 if staying under $1,000 screws up the ride).
If I'm only driving the roads, want to lower the car for looks and don't want to screw up the handling, will using lowering springs screw up the handling dramatically so I shouldn't even bother - if I want to lower the car (07 997 x51) should I just go and do the Motons, JIC/Cross, PSS9, Techart options?
Patience is a virtue I guess.....
Old Aug 30, 2006 | 08:51 AM
ajax1964's Avatar
ajax1964 is infamous around these parts
For what it's worth I had the Cargraphic H&R coilovers installed a week ago...they're coming off today for the pss9's...the ride was BRUTAL for street driving. On smooth roads they're were fun, but god help you if you hit a pothole (hey it's LA, you can't avoid them all). I'll let youu know what the difference is in 2 days.
For the record MEqwkr did warn me
Old Sep 1, 2006 | 12:25 PM
angldrkns9's Avatar
thanks for the help guys! i'm doing either TechArt or JIC
Old Sep 1, 2006 | 09:52 PM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
Consider the X73 from Gert, its an excellent setup.
Old Sep 1, 2006 | 10:22 PM
Zippy's Avatar
Originally Posted by TAnthony
Yes - he did say "Rest of World" springs.... sorry for the confusion.
Any thoughts on these? Are they worthless or should I push him to install aftermarket?
I went from stock to ROW to JICs. The JICs are very good for the $$. If I was you, trying to get a better suspension on a budget, I would contact the board sponsors and ask if they have any used JICs in stock. I know a lot of guys upgrade from JICs to Motons. I am planning the same thing. Why upgrade? Because Motons are better . You know how it is with the MOD-BUG. We upgrade because there is an upgrade available.
You should be able to get a good set of used JICs that will be an excellent upgrade from stock. Put the word out and be patient. You should be able to get a set for a real good price.
Old Sep 1, 2006 | 11:50 PM
secc911's Avatar
secc911 is infamous around these parts
I had Eibach springs on my C2. It looked great! I tracked the car though, and after a while the springs were not doing so well. I was bottoming-out a lot. So...if you're not tracking the car, it's a cost effective way to go. If you think you're going to track it at some point, wait until you can afford coil-overs.
Old Sep 2, 2006 | 08:47 AM
angldrkns9's Avatar
"You know how it is with the MOD-BUG. We upgrade because there is an upgrade available."
I completely agree =P it's never ending... hahahahahh
Old Sep 2, 2006 | 08:52 AM
ajax1964's Avatar
Ok, got the car back yesterday with Pss9's and sway bars (I know, definately over $1000 )......I love it!..the car is tight as a drum, but doesn't kill you on the bumps, and with the sway bars the only limitations with traction are the tires, no body roll. I have the ride setting almost as soft as they can go.
Old Sep 2, 2006 | 09:43 AM
angldrkns9's Avatar
which sway bars did you go with?
Old Sep 2, 2006 | 11:41 AM
toddbee's Avatar
toddbee is infamous around these parts
i have had good luck with the pss9's.
Old Sep 6, 2006 | 11:56 AM
angldrkns9's Avatar
ended up getting the h&rs on ebay brand new 200, the price was cheap enough to just try them out.. i'll sell them again if it doesn't work out...
