b&m short shifter w/Agency Power Porsche 996 Shifter Linkage
Old Aug 28, 2006 | 03:55 AM
melsta's Avatar
melsta has a spectacular aura aboutmelsta has a spectacular aura aboutmelsta has a spectacular aura about
i just install my b&m short shifter and Agency Power Porsche 996 Shifter Linkage but it hits the side of the center console when i put it in reverse should i get the evom one or would that be the same
Old Aug 28, 2006 | 08:48 AM
AIRjordan23's Avatar
AIRjordan23 is infamous around these parts
same thing here. it feels like it touches..but just barely when in reverse. I have porsche oem which is like bnm.
Old Aug 28, 2006 | 09:30 AM
wross996TT's Avatar
I think it may have been installed wrong. I know with my B&M...no problems. There is an alignment tool that can be used with the stock shifter and there are adjustments that can be made. I do not have the shift linkage.
Old Aug 28, 2006 | 11:08 AM
the way i have it, is that the shifter is visually in the center. All gears go in well and all the way. However, in reverse, the linkage touches the side a little. Its also the spring that gets pulled when you put it into reverse, it makes a noise that leaves an impression that its touching the side.
Old Aug 28, 2006 | 11:12 AM
where can you get this tool and do you have a part number
Old Aug 28, 2006 | 11:30 AM
wross996TT's Avatar
Old Aug 28, 2006 | 05:51 PM
sharkster's Avatar
never used the agency power one before but using it with the EVO link it doesn't/shouldn't do that?
Old Oct 16, 2006 | 08:41 AM
Gcookie's Avatar
Gcookie is infamous around these parts
I just installed a B&M shifter and the AP linkage and had no problems; in an 02 coupe. Suggest that you pull the center console and try some adjustments on the left cable. You can also drive without the console to insure you got it right. I had a Schnell short shifter and pull it out for several problems. B&M is the best out there..
Old Oct 16, 2006 | 09:24 AM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
b&m no probs did have to adjust cables ( be sure the cable ends are in correctly)
joseph_number1
Jul 19, 2018 05:45 PM
TrackOne
Aug 20, 2015 12:56 PM
Aug 19, 2015 06:35 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
