WTF.....1.4 bar consistantly now...then TB shutdown.
Old Aug 28, 2006 | 12:39 PM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
Angry WTF.....1.4 bar consistantly now...then TB shutdown.
Well, now my car is acting crazy. I am hitting 1.4 bar everytime I drive her. Then I get the throttle body stutdown.
This happens whenever I go WOT, and also does it when I ease into the gas...and the boost jumps from .3 to .8 to 1.4...then TB shutdown. Now I have to keep a 10mm in the car to disconnect the battery for a minute and it just resets. Maybe I should just put a dash mounted switch so whenever this happens I can just flick it....then put the PCM code in...reset the clock and change all settings to US parameters. UGGGHHHH...this is really irritating.
I have checked all of the boost hoses, the DV's are still connected fine. I looked under the car last night and could see the drivers side wastgate...but could not see the passenger side at all. Of course I was on the floor trying to look...car was not lifted. If anyone has any other suggestions, please let me know...if not to the dealer again.
Old Aug 28, 2006 | 01:09 PM
I forgot, What turbos and WGs are you using?
Your probably on the upgraded springs... and Its a ***** trying to dial them in... especially when the temperature changes...
well, I had the same problem for a while.. you can install a manual boost controller parallel to the stock frequency valve and dial in the boost thats way... so you dont have to drive around with a 10 mm wrench.
The other thing is that diode- it's a band aid fix but it works.
Or you just get a software that is written for higher boost levels.
but if you are on k16/24s or similar turbos you do not need to be past 1.2 bars...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 28, 2006 | 01:25 PM
Turbo Fanatic's Avatar
The pressure hose going to one or both of your wastegates has either fallen off or has a leak in it. Inspect carefully and replace if needed.
Or what Markski said.
I would drive gingerly for now. You are seriously spinning one or both of your turbos.
Old Aug 28, 2006 | 01:26 PM
SMR's Avatar
SMR
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
something is wrong e carful until you found the problem
Old Aug 28, 2006 | 01:32 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
M3, Have you upgraded wastegates, if so which ones?
Old Aug 28, 2006 | 02:46 PM
M3CAB's Avatar
Thanks Mark for all of the info.
Old Aug 28, 2006 | 03:00 PM
Hey Mark, thanks for the PM, lol
Old Aug 28, 2006 | 03:08 PM
M3CAB's Avatar
Hey Stevo, no the wastegates and turbos are 100% stock. I am thinking it may be a hose or something.
Also, I will say that whatever is causing this is making the boost come on real fast and ferocious...then when I shift to the next gear after it hits 1.4 bar, I am in limp mode.
Old Aug 28, 2006 | 03:33 PM
carendt242's Avatar
carendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the rough
what gas are you running @ those levels? if it's pump, i'd stop driving it til you find the problem.
this is coming from someone who just had to rebuild an engine b/c of (most likely) a similar type problem. (that is, unless you're looking for a good excuse to upgrade )
- chuck
Old Aug 28, 2006 | 03:46 PM
Definately sounds like hose of the actuator!
Old Aug 28, 2006 | 03:53 PM
SMR's Avatar
SMR
Im trying to say the same, i would not drive the car or boost the car at all before the problem is solved...the 1,4 can destroy the engien
Old Aug 28, 2006 | 04:02 PM
It might be a stuck check valve or something.... I recall Sharky had a similar issue on a customer car...
funny that it happened as soon as u got it back from the dealership.
9.66
click to view
Old Aug 28, 2006 | 06:14 PM
PorschePhd's Avatar
The wategate is not opening. A hose has to be off. Jack the car up and look for the hose to the wastegate. Either that or it is off on the valve up by the throttle body.
Old Aug 28, 2006 | 11:54 PM
M3CAB's Avatar
Well, Stephen and Markski and Ari and 996TT Stevo were correct. The hose that connects to the bottom of the timing valve for boost pressure control is not even connected.
Many thanks to Markski for walking me through this. Guess it is off to the dealer since I cannot even find the hose that connects...and can't get my hands in there to even connect it...even if I could find it.
Old Aug 29, 2006 | 12:43 AM
What I have noticed is that they can easily be blown off! If you can jack her up and get underneath you will find the end of the hose floating around (hanging loose) Just have to reconnect, but use a tiny jubilee or connection clip to hold the hose down. If you were to take the inner wheel arch liner out you would get a clear view. Good luck!
