Club Sport Cage Installed
Old Sep 7, 2006 | 01:05 PM
  #61
grussell's Avatar
grussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud of
Originally Posted by orijinal_poser
wow your GT2 is amazing!!
do you know how much weight you saved from the RS door panels?? and cost?
FYI - YOUR AVATAR SUCKS!
Old Sep 7, 2006 | 01:06 PM
  #62
SMR's Avatar
SMR
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
Grussel
If you are selling your seats, PM me i want them..
Old Sep 7, 2006 | 01:54 PM
  #63
Me_qwkr's Avatar
Me_qwkr is infamous around these parts
few thinks you can ditch out...Airbags... heck u gone that far why not just ditch those too... Also i see no speakers but i see a radio unit? The seats will make a difference... Also i persume that your trunk is stripped... If not that helps ALOT... dont forget the amp and so fourth from the radio... if you got rid of the A/C...then dont forget to get rid of all the electronics and piping that are behind the dash...that alone would be 40lbs....... how much does the GT2 wieght stock?
Old Sep 7, 2006 | 04:30 PM
  #64
grussell's Avatar
I think the next mods are:
Kevin's 16/26 turbos
Billet Waste Gates
Manual Boost Controller
Evo IC's
Remove front air bags
Sparco S-Light CF seats with fixed alum rails
Sparco steering wheel
Remove washer tank
Old Sep 7, 2006 | 05:34 PM
  #65
orijinal_poser's Avatar
orijinal_poser is infamous around these parts
Old Sep 7, 2006 | 05:55 PM
  #66
Faast996TT's Avatar
Faast996TT is infamous around these parts
You should definitely look into the Brembo GTR brake kit. I put this kit on my last project car and knocked off 12lbs per corner. I'm sure someone has weighed the factory brakes and compared them to Brembo GTR set-up and could tell you exactly how much you will save. You should contact Race Technologies at 310.306.3158 as they are the Brembo distributor for the aftermarket and race kits.
I can also tell you that the pedal feel and resistance to fade on the track was awesome. If you are going to track this car, then I would give serious consideration to the performance and weight savings benefits. Good luck. Car looks great.
Old Sep 7, 2006 | 05:57 PM
  #67
grussell's Avatar
I have Brembo GTR's. They added a few lbs over the PCCB, but they are much, much better.
Old Sep 7, 2006 | 06:09 PM
  #68
Faast996TT's Avatar
Sorry, didn't see that on the list of upgrades. Good luck with the project.
Old Sep 7, 2006 | 06:43 PM
  #69
Me_qwkr's Avatar
hey where did you get the rear quater widows at and who in So,cal is doing your work... as i believe your in cali right?
  #70
grussell's Avatar
Lucent Motors
Old Sep 8, 2006 | 01:44 PM
  #71
sharkster's Avatar
take out the mats!
PelicanParts.com
Aug 21, 2015 01:37 PM
ppwchiang
Aug 20, 2015 10:28 AM
