Engine noise normal
Old Jan 22, 2004 | 10:17 PM
ebaker's Avatar
ebaker is infamous around these parts
They'll probably add another chain guide on the 997 to fix it. It doesn't bother me as long as it's not something that is going to break.
Old Jan 22, 2004 | 10:29 PM
luting_chen's Avatar
luting_chen is infamous around these parts
true that... and i'm trying to get used to it...
that's why i always have my upgraded stereo system turned on loud now... haha
Old Jan 22, 2004 | 10:57 PM
ebaker's Avatar
At least it's not those nice quiet toothed rubber belts.
Old Jan 23, 2004 | 06:37 AM
DAVE W's Avatar
DAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to behold
i'd just like to say that "common" is probably more correct than "normal". just because they all do it (or atleast most), and it is seemingly harmless yet annoying, doesn't make it "normal"...its just like our wives *****ing about our mod $$.
-dave w
Old Jan 23, 2004 | 06:56 AM
Rob's Avatar
Rob
Rob is a glorious beacon of lightRob is a glorious beacon of lightRob is a glorious beacon of lightRob is a glorious beacon of lightRob is a glorious beacon of light
One could say the noise adds character.
Old Jan 23, 2004 | 08:03 AM
Joe Weinstein's Avatar
My car makes no such noise. I would be calm if it is not harmful,
but I would certainly prefer that it not happen.
Joe
Old Jan 23, 2004 | 08:36 AM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Joe - How many miles do you have on your Turbo?
Old Jan 23, 2004 | 09:01 AM
7000 miles
Old Jan 23, 2004 | 09:31 AM
cporterfield's Avatar
cporterfield is infamous around these parts
"One could say the noise adds character"
___________________________________
Yeah, bad character. I am going to continue to try to find a way to correct the problem. To say it is normal and give up is not acceptable. If each the car blew it engine at 10K miles, it would be both normal and common, but not acceptable.
BTW, my car has 14,100 miles on it; 4K since September :-)
Old Jan 23, 2004 | 10:08 AM
Arnie's Avatar
Arnie is infamous around these parts
Noise
My car has made it since new and it does not do it all the time. When I step on the clutch it goes away. I was told it was the transmission and rotation of the gears while stopped. That is why the noise goes away when you step on the clutch. It has nothing to do with the engine. At least that is what my dealer said. About 50% of the turbos have this problem which is "normal" I have 6,000 miles on the car now and it is not as noisy as at wasl
Old Jan 23, 2004 | 10:13 AM
I hear that if you get the FabSpeed Loud exhaust, the
chain noise problem goes away completely
Old Jan 23, 2004 | 10:16 AM
Arnie's Avatar
HAHAAHAH
That is funny
Arnie
Old Jan 23, 2004 | 10:17 AM
The clutch noise and the engine noise are similar sounds, but they are two different "problems".
Old Jan 23, 2004 | 11:21 AM
"I hear that if you get the FabSpeed Loud exhaust, the
chain noise problem goes away completely"
I hear if put on by-pass pipes, that all rattles also go away.
Old Jan 23, 2004 | 02:22 PM
ebaker's Avatar
I'm suprised there is so much chain noise since the turbo is on the "Briggs and Stratton" cam lobes at idle. It may go away with the clutch pressed because the throw out bearing pushes the crankshaft a few thousandths rearward(?)
I saw where some Nascar teams now use toothed belts instead of a cam chain to dampen the camshaft torsional vibrations. I'd rather have a 200,000 mile chain than a 40,000 mile belt though.
