gt3 brake cooloing duct
Anyone here got these installed?Dealer ordered the gt3 cooling ducts telling me it works with the 996 turbo,it arrived not too long ago and they discovered that it does not work/fit??The other option is to try the gt2 ducts.,anyone tried this set up?
GT3 CUP ducts are different from the regular gt3. I have the cup ducts on my car and they work fine. They do hang a bit lower on the car so you may scrape them but they are flexible. It would appear that they should grab alot more air for cooling the front brakes.
I looked into doing those but, they were going to be too low with my coil over kit. I had my shop run some cooling hoses in from the front and out the front end of the wheel well. It works very good.
GT3 CUP ducts up front, they are not the same as the regular GT3 ducts. these are two pieces riveted together. My car is as low as they go and yes the ducts hang down, but havent ripped a front one off yet, notice I said front. the rear ducts are from the GT2 and yeah ripped one off running over a piece of rubber at the track.
This set up is cheap, 30% more brake duct air flow and OEM porsche motorsports parts.
Running ducts like mitch did is awesome but if like the sportec set up can be very expensive but effecient and badass.
Originally Posted by gneypiks
Hi Tom;
Thanks for the info.,is this a DIY.Do you need to take the existing one out as it looks like it is slotted into one of the tierod ends.?Thanks to all for their comments.
Originally Posted by Gabriel
Can you combine them with a BBK?
you can easily rivet some rubber/plastic floor coping to the stock ones. the coping is much more pliable. you can always replace the added coping when wornn out. easy and simple. I went through a couple sets of the GT3's.
