Dyno HP...
Old Jan 27, 2004 | 09:32 PM
luting_chen's Avatar
luting_chen is infamous around these parts
Dyno HP...
I'm planning on dynoing my car after the Stage 4 GTR kit is installed...
if the dyno machine is SAE... and it's RWHP that I get...
what's the estimate real HP on crank?
Old Jan 27, 2004 | 10:09 PM
MBailey's Avatar
Most will quote a 15% drivetrain loss from crank hp to hp at the wheels. This is only an estimate. There are extensive discussions on this previously. You may want to do a search. Its imp if the dyno is two wheel or four wheel. I think 4 wheel dynos give lower numbers.
Old Jan 28, 2004 | 02:53 AM
barev's Avatar
barev is infamous around these parts
4wd's tend to lose about 25% but these are all estimates, and what's really important is the car's rwhp.
Old Jan 28, 2004 | 11:15 AM
StephenTi's Avatar
StephenTi is infamous around these parts
In terms of drivetrain loss, generally, 15% is used for FR (front engine rear drive) cars and 20% for AWD.
The most common way to actually measure drivetrain loss it is to use the dyno to measure it... I believe it's done while the drivetrain is coasting down, as the dyno compares it's known momentum (and/or drag, hence deriving the time it takes to coast down) against the difference when a car's drivetrain is introduced into the equation. This is an over-simplified explanation, but you get the idea... it's kind of a "reverse" dyno pull.
Then, one has to take into consideration altitude, temp, etc... for the final correction.
Stephen
'01 Turbo Ti
1stephen1.com
Old Jan 28, 2004 | 11:22 AM
StephenTi's Avatar
While it is true that an automatic tranny 4wd truck may experience a 25% drivetrain loss, our Turbos' drivetrain are much more efficient than that. I'd imagine it's somewhere beteen 15~20%.
Stephen
'01 Turbo Ti
1stephen1.com
Old Jan 28, 2004 | 12:15 PM
thanx guys ^_^
Emre@Esmotor
Oct 19, 2015 12:06 PM
flewis763
Oct 4, 2015 04:14 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
