Ditching 996TT hydraulic clutch assist?
Old Aug 31, 2007 | 07:21 PM
  #31
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
Originally Posted by jrgatfh
I'd like to have the directions to remove the spring just to try it out. Can someone clarify if if removing the spring gives you as much stiffness and feel as going to the gt2 setup because I am still a little confused lol, thanks guys!
Me as well. The stock clutch is wayyy to soft. Can someone explain how to remove the spring and explain what the accuator does and how to remove it? I heard you can save quite a bit of weight by removing it. Thanks!
Old Aug 31, 2007 | 08:04 PM
  #32
Mine is all nonhydrolic. It is stiffer then a GT2 clutch for sure...
It take somewhat getting used to it. I have mixed feelings only becasue my foot hurts the next day LOL
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 31, 2007 | 08:38 PM
  #33
CarNerd's Avatar
Markski, really that bad huh? Did you remove both the spring and accuator?
Old Aug 31, 2007 | 08:49 PM
  #34
Everything is gone... I did not do it buts its fully manual.... its that bad.
You feel the clutch but its really tough if ur stuck in traffic.
9.66
click to view
Old Aug 31, 2007 | 08:55 PM
  #35
Zuma 911's Avatar
Zuma 911 has a spectacular aura aboutZuma 911 has a spectacular aura about
Does anyone have a link to the PET. thanks in advance.
update....found the PET exploded views online..Thanks
Old Aug 31, 2007 | 09:13 PM
  #36
CarNerd's Avatar
Any suggestions on what i should keep then...?
Old Sep 1, 2007 | 02:34 AM
  #37
I have been told that u can swithc to a GT2 set up.. parts around $500 but I have no idea what is involved.
9.66
click to view
Old Mar 31, 2008 | 01:29 AM
  #38
FlyYellow's Avatar
FlyYellow is infamous around these partsFlyYellow is infamous around these parts
can anyone comment on removal of the clutch power spring ?
specifically, how much stiffer is the clutch pedal? is it more/less stiffer than a gt2 setup?
Old Mar 31, 2008 | 10:58 AM
  #39
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
Here is a pic...you remove # 9. Thats the helper spring. I will warn you watch your eyes when taking this out, it wont kill you but might hurt a bit
Old Mar 31, 2008 | 11:22 AM
  #40
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Evoms has a GT2 conversion kit. $980.
Old Mar 31, 2008 | 11:24 AM
  #41
robertp's Avatar
I was advised not to do this because it creates a dead spot in the clutch engagment.
Old Mar 31, 2008 | 02:20 PM
  #42
here is my update.
I had all the assist thrown away. But still have some issues. Probably due to the clutch etc. So I ordered all gt2 parts and it came out to be $450 with my dealer discount. It includes the master slave, the slave cylinder, the clutch spring and the hose that connects to the slave. I should have it installed Saturday.
Markski
9.66
click to view
Old Mar 31, 2008 | 02:39 PM
  #43
rolfjahn's Avatar
rolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to beholdrolfjahn is a splendid one to behold
subscribed
Old Mar 31, 2008 | 03:09 PM
  #44
robertp's Avatar
here is my update.
Markski
Much better deal than Evoms.
Remember, the GT2 uses brake fluid not power stearing fluid to power the clutch. You need to clean out any existing parts.
Old Mar 31, 2008 | 03:39 PM
  #45
CarNerd's Avatar
Why's that?
