GT2 Bi-turbo or Twin turbo?
Originally Posted by GT2
Bi-turbo = 2 turbos working at the same time
Twin turbo = each turbo for 3 cycliner
they work parallel to each other instead of in series... so one does not push boost into the other....
2001 996TT 3.6L and stock ECU
Cleve
Originally Posted by cgmeredithjr
You are confusing sequential turbocharging with twin turbocharging. Correct me if I am wrong, but Supras and RX-7's came standard with sequential turbocharging where one turbo would spool quickly at low RPM and then the second turbo would join in or takeover at higher loads and RPM. Turbo Porsches are true twin turbo set ups where both turbos are working together all the time...not in sequence.
Cleve
Cleve
so... Bi-turbo = Twin turbo
Both turbos working together all the time and the size are the same
Each turbo for 3 cyclinders
For example; the Audi B5 S4 and C5 2.7T are called "biturbo" cars, but have two turbos that make boost at the same time...just like the Porsche's twin-turbos.
As Cleve said; you're thinking of "sequential turbos".
Originally Posted by Divexxtreme
As I said; "biturbo" and "twin-turbo" are the same thing. They both make boost at the same time, only they have different names.
How was Bahrain
thanks again!
Hypothetically could you put four turbo's on a 911? Put huge turbo's like GT40's which usually have horrid lag but then hit like cannons, then smaller turbo's ahead of them that will spool faster. I know quad turbo's have been used in the past on other makes. Can they be used on P-cars?
Cleve
