Gt640 Kit!!!!
Old Oct 15, 2006 | 06:07 PM
andyk79's Avatar
andyk79 is infamous around these parts
Gt640 Kit!!!!
Hey guys I just installed the GT640 Kit and I need help on installing the 5 bar fuel regulator. Does anyone have a detailed write up on this. Also how long should I break in the turbos before i really get on them
Andy~
Old Oct 15, 2006 | 06:23 PM
fasteddiett's Avatar
fasteddiett has a spectacular aura aboutfasteddiett has a spectacular aura about
Andy~
I've done it twice and the best advise i can give is to get some bandaids for when you are done... not very helpful , but... the best insight i can offer....
Old Oct 15, 2006 | 06:27 PM
tradin1's Avatar
tradin1 is a splendid one to beholdtradin1 is a splendid one to beholdtradin1 is a splendid one to beholdtradin1 is a splendid one to beholdtradin1 is a splendid one to beholdtradin1 is a splendid one to beholdtradin1 is a splendid one to behold
the turbo break in should be around 500 miles, no boost at first, then more and more.
Old Oct 15, 2006 | 07:02 PM
the 5 bar is a ***** no room. I dont suggest doing it... honestly, I watched my mechanic do it once so I learned.. but if u never seen it ... its tough... u need to know what to take off and move over... then u need to knwo where and how the clip goes in the FPr.... taking it off is easier but getting that pin back in is tougher.... I can do it in 30 minutes... take it to sharky or something...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Oct 15, 2006 | 07:18 PM
RT7's Avatar
RT7
Show-N-Go like J-Lo Mofo
RT7 is infamous around these parts
I agree with Markski. A ***** might be a little bit understatement.
Old Oct 15, 2006 | 07:35 PM
FL TT's Avatar
FL TT is infamous around these parts
sick wheels man!
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
It took me 2 hours and IMO the hardest part of the kit.Will need band aids for sure.If i recall correctly i did it with the passenger turbo off and the coil packs removed using a long tip needle nose.You can see it from underneath if you shine a light up next to the cylinder head.The fpr is gold in color(round) and you need to remove the clip that holds the regulator in the housing(the hardest part as there is no room in there).Remember the order that the regulator comes out.Hope this helps.
Old Oct 15, 2006 | 07:38 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
I did a 200 mile break in with 6-7 cycles. You should slowly introduce the boost after 150miles
Jag
Old Oct 15, 2006 | 07:42 PM
I did it from the top... u take off the secondary air pump with 5 screws... ist all the way back but can be done.. i did it 3 times... this way u dont have to take any turbos.. thats a lot of work... just my opinion...
the problem is if he doesnt know what to look for it will be hard to see.
9.66
click to view
Old Oct 15, 2006 | 07:49 PM
joetwint's Avatar
But he's doing a 640 kit and gonna have to change the turbos and the plugs anyway because that is part of the kit.If you do it with the turbos off you don't have to take the air pump off.JMO
Old Oct 15, 2006 | 07:55 PM
sorry I dont know that hes changing the plugs.. and I assumed he already had the turbos installed...
9.66
click to view
Old Oct 15, 2006 | 07:59 PM
joetwint's Avatar
Your right Mark if he installed the turbos already.
Old Oct 16, 2006 | 11:49 AM
PorschePhd's Avatar
Andy~
Andy,
Sorry I should have emailed you this Sat. I got stuck in the Karate tournament longer than expected. Drop me an email with a number to call you at and I will walk you through it today on the phone.
Jul 29, 2019 11:13 AM
ECS Tuning - VW
Aug 27, 2015 08:50 AM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
Aug 21, 2015 06:34 AM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
