OEM GT2 wheels on a 996TT - Do they fit?
Old Oct 17, 2006 | 07:06 PM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
I believe Tom is running GT2 wheels as track set
https://www.6speedonline.com/forums/member.php?u=6211
Old Oct 17, 2006 | 07:20 PM
DJ's Avatar
DJ
they will fit in fact they used to be on that car before the techarts, then hre's .....
Old Oct 17, 2006 | 07:37 PM
zona's Avatar
zona is infamous around these partszona is infamous around these parts
GT2 and the TT have the same offsets in the rear(45mm). The TT is narrower by 1/2" on each side.
The GT2 has a more aggressive front offset by 10mm(+/-3/8"). The TT (8.0"/50mm et)wheel is 1/2 narrower, but with the GT2'S offset and width the GT2 wheel (8.5"/40mm et) extends 5/8" wider from hub centerline out and 1/4" less from the hub center in than the TT wheel.
I believe the narrower TT wheels fit a GT2.
-Z
Originally Posted by vincentdds
Not true. You can not fit TT onto a Gt2. Only vice versa .Due to difference in offsets.
Old Oct 17, 2006 | 08:19 PM
laj_c4s's Avatar
laj_c4s is infamous around these parts
Is fender rolling needed to run the 12's in the rear if you are not at the track? Who does the rolling?
roy
Old Oct 17, 2006 | 08:21 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
roy
Just to poke around on the street they will fit fine but may rub the fender liner. As for the rolling it is you or a body shop.Kevin
Old Oct 17, 2006 | 08:36 PM
Turbo Fanatic's Avatar
If it rubs it's going to rub. You should get your fenders rolled if you any combo that rubs..
Old Oct 17, 2006 | 08:54 PM
tom kerr's Avatar
Sorry for the late chime in was out of town!!
Just my experience, I run the GT2 wheels (no spacers or anything) with the 235/315's. I have had both MPS2's and cup tires. As you can see by the avitar my car is as low as it can be. I personally have NO problems all. Although the GT2 has the rear fenders rolled at the factory ours do not and do not (by my experience) need to.
Remember also I run -1.75 rear camber. The car is both street and track driven (hard) and no problems. those wheels are an awesome track wheel and can be had for 1-1.5K.
Also remember they are solid not hollow so somewhat heavier.
I love them. (Your results may vary)
tom
Old Oct 18, 2006 | 12:40 AM
zona's Avatar
Now that I didn't know!
Are all GT2 "twist" solid?
Old Oct 18, 2006 | 09:58 AM
tom kerr's Avatar
Can only speak for the ones I have. I was told it was to "handle" the increased torque and power of the GT2 car.
Old Oct 18, 2006 | 11:13 AM
03-turbo911's Avatar
Senior Member
All GT2 wheels from '02 to '03 were solids. They went hollow spokes when they changed to the GT3 style in '04-'05.
Old Oct 18, 2006 | 10:23 PM
Zippy's Avatar
I have 245s and 335 RA1s on 8.5x18 & 12x18 BBS wheels cut to GT2 specs. The top of my fenders are 25.5" off the ground with -1.4' camber front and back.
Rears need to be rolled & plastic inner fender liners need to be heat gunned and flattened back. MPSC or PS2s are easier to fit. If you have a good jack, air socket and heat gun you are set. This job can easily be done at home.
Old Oct 18, 2006 | 10:30 PM
oak's Avatar
oak
I have a set of 04 GT2 wheels and they are very heavy, are you sure they are hollow? I don't recall the back sides of the spokes were dished out.
Old Oct 18, 2006 | 10:51 PM
cnc's Avatar
cnc
Awaiting Email Confirmation
cnc is infamous around these parts
I have a set of GT2 wheels and OEM tires, no miles, for sale, pristine condition. PM if interested.
Also GT3 seats in natural gray leather.
Old Oct 19, 2006 | 08:02 AM
Senior Member
My bad Oak, I meant a lighter wheel.
Old Oct 19, 2006 | 12:49 PM
calbobba996TT's Avatar
calbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the rough
I am running factory gt2 wheels with hoosiers at the track with no problem
Boris
