OEM GT2 wheels on a 996TT - Do they fit?
Old Oct 19, 2006 | 01:03 PM
  #31
tom kerr's Avatar
Zippy, are you running that tire set up at the track with no problem? And does it make a difference?
Old Oct 19, 2006 | 05:04 PM
  #32
spidey's Avatar
spidey is infamous around these parts
I have the same tire setup and have no problems (only slight rubbing on the rear plactic inner liner).
as far as if makes a difference, I have no idea since I have not run the TOYO's in a different size ......
Old Oct 19, 2006 | 05:13 PM
  #33
tom kerr's Avatar
spidey, thanks for the input, have you rolled the fenders and done what Zippy did?? Cause I'm ready to get a set!!
Old Oct 19, 2006 | 05:17 PM
  #34
spidey's Avatar
Have not rolled the fenders...
My wheels are a little different though (9" front and 11.5 rear", with a 5mm spacer in front to clear the Brembo GTR's).
One other thing, on a steep uphill sweeper with the front tires loaded on compression while braking (steering cranked to the right), you may experience a "slight" rubbing on fender liner too. Probabaly due to my lowered ride height.
Old Oct 19, 2006 | 09:37 PM
  #35
tom kerr's Avatar
Thanks, if they aint rubbin they aint big enough!! I'm going to try it for the next set, thanks again for the help
tom
Old Oct 19, 2006 | 11:25 PM
  #36
Zippy's Avatar
tom
I like You! Tom, with enough bending of steel and melting/reshaping of plastic, they fit like a dream!
Old Oct 20, 2006 | 01:38 AM
  #37
Red 9's Avatar
Red 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond repute
Do not want to hijack but it is sort of relevent. I want to fill guards as much as possible but still clearing bodywork and liners with as much wheel /tyre as possible-- so my question is this-- laying a straight edge(horizontally) across the centreline of wheel/tyre and then measuring to the back of the wheel surface(where wheel contact is made with hub) What is the measurementfront and rear? What is measurement from visual outer guard to tyre sidewall? How much camber(approx)? How much lower than stock? My car is to be used for street/road car with occasional track use. I want to order wheels and are trying not to make a mistake and I figure there are likely to be a few here that have solved this precise problem.
Old Oct 20, 2006 | 01:45 AM
  #38
yellowturbo's Avatar
yellowturbo is infamous around these parts
tom
I'm now convinced I want to go with wheels that are GT2 specs and put those big RA1s on. I wouldn't even have to worry about switching them back and forth since RA1 is fine for street tires (not a daily driver).
I just need to find the right wheels if I am going this route since I'd like something with a little more flash than stock wheels for the street.
A friend has suggested getting CCW wheels (very reasonably priced and I can get the black centers with polished lip that I would like). I really like the look of the HRE C20 (black center and polished lip) but they're very pricey.
Any other suggestions?
Old Oct 20, 2006 | 09:56 AM
  #39
spidey's Avatar
The RA1's are fine for street use and more durable than I expecetd.
Someone was selling a set of used Kinesis rims in GT2 size a while ago (black centers too). May want to try the search function.
With KINESIS sold to Lexani, out choices for 18" wheels just got reduced ....
However, I just ordered a set of HRE C20 in GT2 wheel size/offset (customized to clear my GTR brakes) from Sharkwerks..... (and these are not reverse drop centers so there should not be issues with water collecting in the barrel and causing vibration issues...)
Old Oct 20, 2006 | 10:21 AM
  #40
tom kerr's Avatar
Zippy thanks! and my plan exactly!!!!!
Old Oct 20, 2006 | 11:10 AM
  #41
Those were sold within a few hours of being posted!
Old Oct 20, 2006 | 11:36 AM
  #42
tom kerr's Avatar
Buy a set of GT2 wheels and have them painted black or yellow.
Old Oct 20, 2006 | 02:33 PM
  #43
laj_c4s's Avatar
laj_c4s is infamous around these parts
sorry man, but you have to move quick around this place.
i've seen many sets of wheels come and go, by thinking if i should pull the trigger.
it was actually 20 minutes
roy
Old Oct 20, 2006 | 02:45 PM
  #44
SHANKENFELTER's Avatar
SHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud of
I did a search on the forum but there wasn't anything conclusive on whether the 18x8.5 (fronts with 235/40-18 rubber) and 18x12 (rears, with 315/30-18 rubber) will fit on a 996TT.
Does anyone have any experience with this? Were there different offsets between the GT2 and the 996TT? I don't want to use spacers, etc.
Thanks in advance for the help.
They do fit - might need to roll the fenders but I think Duane did that already.
Wanna sell me those HRE's?
Old Oct 24, 2006 | 05:52 PM
  #45
Originally Posted by Zippy
I have 245s and 335 RA1s on 8.5x18 & 12x18 BBS wheels cut to GT2 specs. The top of my fenders are 25.5" off the ground with -1.4' camber front and back.
Rears need to be rolled & plastic inner fender liners need to be heat gunned and flattened back. MPSC or PS2s are easier to fit. If you have a good jack, air socket and heat gun you are set. This job can easily be done at home.
Zippy- Quick question about using the heat gun. From what you indicate, just remove the wheel and then start heating the plastic inner fender liners. Do they warp a certain way or do you have to push them out? Do you heat it from the inside of the wheel well or from the 'outside'.
