PSS9 - whats a good deal on these
try a search. The pros and cons of the PSS9's have been discussed at length.
In short, you can't put them as low as you want. There are issues with them riding on the bumpstops if you go as low as GT2 ride height. They are however height adjustable, and the stiffness is adjustable by a dial on the top of each spring.
If you are tracking a ton, these might not be agressive enough for you. But if you want a better, lower, adjustable suspension, and you're only tracking a few times a year, these are probably your best deal.
They run from around $2300 - $2900 new. Expect another $500 - $1000 for install.
Originally Posted by sharkster
I wouldn't go lower than 1.25 inches or you'll be in danger of riding on the bump stops...
Originally Posted by ari
How do you measure? My car is already lowered with PSS9s. I also have 15MM spacers which probably work the suspention a bit harder (longer lever arm). I swear it feels too low sometimes.
nick49
Aug 28, 2015 01:40 PM
