Front differential oil leak - question
Old Nov 5, 2006 | 01:28 PM
timf's Avatar
timf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud of
About a year ago I noticed an 'oil slick' on the under belly of my '03 TT starting just behind the front diff. Took it to the dealer and they replaced an O ring where the prop shaft enters the diff housing.
Now it looks as though the problem has come back.
I'm wondering if anyone else has had this problem and what the solution was.
I suspect the dealer will replace the O ring again, but that may not be the root cause.
Any comments or suggestions before I take it in ?
The car has done just over 20,000 miles and has never been tracked.
Thanks Tim
Old Nov 5, 2006 | 05:37 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
Well, there is a left and a right, theres a small possibility that the fixed side is ok, but I can't say for sure without seeing it.
Old Nov 6, 2006 | 11:12 AM
wross996TT's Avatar
When mine had a very small leak (i mean it was only detected when I had PSS9 suspesion installed...just a little wet spot on the underside of the car) they replaced the whole front differential. Told me Porsche wanted to replace the whole deal vs. fix seals.
Old Nov 6, 2006 | 09:28 PM
tblackj's Avatar
tblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond reputetblackj has a reputation beyond repute
Ditto, but the funny part was ... my car was approximately 10 days out of warranty and they failed to notice that until the diff was out and torn apart. It was really funny.
Old Nov 7, 2006 | 02:45 PM
timf's Avatar
Goes in tomorrow....
Thanks for the insight guys.
Just spoke with SA and they can take a look at it tomorrow, hopefully this time it'll get fixed permanently.
Also getting them to take a look at the clutch accumulator as it seems to loose pressure assist after the car has been sitting for about 6 hours.
Previously it'd go days with no significant leakage.
Tim
Old Nov 8, 2006 | 11:19 PM
timf's Avatar
New stuff...
Well, my TT is getting a new front diff and clutch accumulator fitted.
The diff was leaking from the same place so they decided to replace it.
All I need now is a new tranny to complement the new engine I had fitted at 7,000 miles and I have a completely refreshed engine and transmission ;-) jk
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
Senatorblutarsky
Aug 28, 2015 12:44 PM
gulf gt
Aug 27, 2015 10:27 AM
