How do you launch a tip. car?
Old Nov 15, 2006 | 06:02 PM
JWC's Avatar
JWC
JWC is infamous around these parts
Hey Markski I was wrong when I told you my 1/8 mile speed was 93 ....it was 96.39 MPH.
Old Nov 15, 2006 | 06:08 PM
sharkster's Avatar
hey guys.. sorry I didn't see this one earlier.. I'll write something up in a bit
Basically, lower the tire pressure (I assume you're using decent 18s?) in the rear. Have it pumped up to 40 in the front. Pull up the hand brake when you're staging. Hold the foot brake down as much as you can and start stalling her up. Make sure you've down shifted into 1st gear and have the PSM "off". Now this is assuming you have stock brakes? Get it up to about 2600-700 rpms and hold it for a bit to get some boost. Then just before you feel it start to "wander" drop the hand-brake and at the same time let of of the brake whilst pressing the gas as hard as you can....
Old Nov 15, 2006 | 10:01 PM
JWC's Avatar
JWC
Thanks I will give it a try. I am running Kinesis K18r rims with Michelin Pilot Sport 315/30/18's in the rear.
Old Nov 15, 2006 | 10:15 PM
sharkster's Avatar
JWC give what I said a try. You have stock brakes right? I managed to stall higher with that.. Hmm actually I have another neat party trick for you if you like... I have the EVO higher stall torque converter sitting here if you're interested
Old Nov 15, 2006 | 11:54 PM
JWC's Avatar
JWC
Yes I have the stock brakes. Whats the deal on the EVO higher stall torque converter?
Old Nov 16, 2006 | 12:09 AM
ramone's Avatar
ramone is infamous around these parts
Yes, I'd like to know too
Old Nov 16, 2006 | 01:06 AM
Turbo Fanatic's Avatar
Imagine your automatic's clutch revving higher before dumping the clutch. much harder takeoffs.
Old Nov 16, 2006 | 12:25 PM
sharkster's Avatar
Well it allowed me to stall the car higher by about 400-500rpms and launch way harder:P The torque converter was reveined:P Helped me get into the 1.601 60 foot range
Taken from EVO's product page ($4345 without a core exchange):
Tiptronic Torque Converter
SKU:CLUTC996TT
Our unique re-veined design will offer excellent drive-ability while allowing the engagement rpm to be raised for harder and faster launches and 1/4 mile times. A rebuildable core exchange is required. Tested successfully up to 800HP.
First $1000 takes it It's VERY heavy so shipping won't be cheap. Maybe $150?
Old Nov 27, 2010 | 11:26 AM
MikeR397's Avatar
MikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant future
How much damage, and how fast, would the above technique cause to a stock torque converter? How much $ for a new torque converter?
Old Nov 27, 2010 | 11:32 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
1695$
http://www.evoms.com/marketplace/ViewProduct.asp?Now=11%2F27%2F2010+10%3A32%3A02+AM &ProductID={710EA6CC-05D4-4D6D-B2BD-DE1C77F9C60E}&OrgID={CA5E16BC-D877-4137-8237-7EB9084DD3D8}&ParentID={54EDE288-22B5-45C3-83AB-B002C337C06B}&Curr={54EDE288-22B5-45C3-83AB-B002C337C06B}
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
hydeaway
Sep 7, 2015 07:01 PM
Aug 21, 2015 06:34 AM
