996TT RUF 550 on the Dyno
Thanks very much John, and i knew of course you werent bashing ruf, i was just really interested and wanted to find out more
Thanks again, much appreicated.
adam
adam
. Supossedly a Ruf turbo was disected to learn what they were doing to make such fast cars. You know the saying "Imitation is the best form of flattery"...
Interesting about the "Ruf" modified K16 turbos - I have a TechArt modified car/engine and it has "moded" turbos - K16 - to produce 550hp (not at the rear I'm sure). Stands to reason Ruf and TechArt are pretty much on the same page w/ mods - they both are well connected w/ the factory too - and share engineers although they do not talk much about this openly. I've not run against a Ruf car (520 or 550) but would love to some time to see how they compare.
Also find it interesting I have not read much about TechArt moded cars/engines here - seems most folks are just buying TechArt "cosmetic" parts.
Hi michael,
I spent 9 months at the ruf factory last year, and all of my summer there this year, and i can safely say the two companies share nothing. (personnel, ideas etc etc)
all the best
adam
all the best
adam
If this X50 dyno'd 550bhp without a remap on the same dyno the RUF dyno'd 550 as well then I'm sure the X50's had a remap done even if the present owner is not aware. There's an easy solution for this though. What kind of boosting was the car doing? If its doing 0.8/0.9Bar as stock than its not doing 550bhp (not even close) and to prove it its a matter of math, I could dig out the flow numbers of K24's and 996 Turbo's engine (which is 12lbs per minute if I'm not mistaken) but Jean knows this even better than me so if he can step he's save me the work. On the other hand if you see 1.0-1.2bar on the gauge then its remapped and its probably doing 550bhp as the Ruf but with a higher boost threshold and lag.
Originally Posted by Bruce
On the 1st. page of this thread I posted a photo of a turbo from my Ruf 550 conversion. The numbers on the housing are pretty visible, looks like K24's to me but I don't know what all the numbers mean. I don't see the number 16 anywhere but 24 is clearly visible. I don't really care, the car is plenty fast for me and it has given me absolutely no problems.
What is your car boosting at? I have never seen higher than .9, just curious what you see.
Originally Posted by Kevin
I for one have seen more Ruf turbochargers come thru my hands than most people. There is alot of mis-information in this thread.. If the car in question has K16 hybrids on it then someone installed the wrong turbochargers. The turbochargers that are on the 550 and 590 Ruf cars are K24 based Hybrids... Plain and simple.. I have back to back dyno sheets on my dyno proving this, and have torn multiple units apart.. The engine kits are not just bolt on turbochargers.. It is more indepth than that.
John D, the wastegate kit that is on your car is mine BTW.. Along with your turbo design..
Is there something about Ruf turbos that you're having to see so much of them? I haven't heard much about actual turbo failures on this forum so it's peaking my interest on how to keep mine happy (besides the warm up and cool down procedure I follow, along with the frequent oil changes).
