Question for the programers???
Old Dec 10, 2006 | 12:25 AM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
What does Neil, Todd or any other programers think of this?? These are the guys who won at 24 hours of Daytona .... very interesting??
The TPC/Uni-Q with PnP(Plug n Play) technology is TPC Racing’s new and revolutionary approach to engine management. Developed by DASTEK, the maker of Unichip, based on their known innovative concept now combined with cutting edge electronic hardware.
TPC/Uni-Q is available as an option* for any vehicle equipped with TPC Racing supercharger kit and most turbocharged vehicles. TPC/Uni-Q consists of a piggy-back computer with 106,496 precisely tuned adjustments, making its sophistication unmatched. All this electronic information is routed through a true “Plug n Play” wiring harness** that simply plugs into the factory ECU. TPC/Uni-Q differentiates itself from other methods of aftermarket engine management by delivering 100% of the available power from your engine’s entire rpm band, 100% of the time without interfering the factory ECU’s cold start, knock sensors, coolant and air temperature sensors, oxygen sensors, pressure and altitude correction tables, or anything else the car manufacturer spent years on developing. TPC/Uni-Q works in harmony with the factory ECU in “closed-loop”, unleashing the best possible performance from your engine’s mechanic design without compromising drivability under any driving condition and environment.
Old Dec 10, 2006 | 09:10 AM
Billystang's Avatar
Billystang is infamous around these parts
Very interesting!!
I m wondering whats the hp for the 996TT 500hp?without any upgrades?
Lets see what the experts has to say.
Old Dec 10, 2006 | 09:55 AM
PorschePhd's Avatar
This is the Uni-chip. Do a search. They are not a wise choice. Why would you add a computer to a computer. That makes no sense. You are adding data on top of data and jamming the ECU from doing what it wants to do...That is never a good thing and is techonolgy of the 80s.
Old Dec 10, 2006 | 11:31 AM
robmd99's Avatar
thanks Stephen
Old Dec 10, 2006 | 12:38 PM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
I can attest to that. I built an engine for a street rod in the early 90's and piggy-backed a computer onto the GM ECU. It was a nightmare and never worked properly. Ended up having Lingenfelter burn a chip and all was well.
Old Dec 10, 2006 | 01:31 PM
cpu77's Avatar
cpu77 is infamous around these parts
Same here piggy backs try to fool the oem ECU to do what it wants. I too have had a couple bad experiences with piggy back garbage!
riverflyer
Sep 1, 2015 04:22 PM
cordsig79
Cayenne 955/957
Aug 28, 2015 12:36 PM
Aug 21, 2015 06:34 AM
Nissan GTR
Aug 19, 2015 02:11 PM
