PSM & ABS Faluire
Old Dec 20, 2006 | 10:51 PM
AzExoticLover's Avatar
AzExoticLover is infamous around these partsAzExoticLover is infamous around these parts
Originally Posted by MARKSKI
cant be the maf because ur car is still running fine.,.. its the plugs...
u pushed it too far Dave...
a bad maf will idle roughly...
markski
I think I did pushed it a little to hard too.... I have it dialed down now a bit to just barely see 1.30 bar and hold it all the way through the gears on 100 octane..
My pump mode is dialed in perfectly!
Email me, and I will shoot you over the Dyno Sheets
Again, Thanks for ALL the help over the phone, PM and ect.... I have learned a TON in the last 48 hours... Keep the inof coming! Thanks Mark!
Thanks Mark!
Old Dec 20, 2006 | 10:57 PM
dr_sharp's Avatar
dr_sharp is infamous around these parts
This is a good thread... keep the info coming!
Old Dec 20, 2006 | 11:51 PM
Turbo Fanatic's Avatar
Usually when the MAF goes or is gone, you will run rich as a failsafe.
Old Dec 20, 2006 | 11:55 PM
thast exactly correct.... thats why I know its the plugs.. plus Dave pushed the car past 1.3 bars I think... and the plugs should be changed in my opinion every 5K when ur running 1.3 bars on big turbos...
here is what u need :
Denso Double platinum 3245 PK20PR-P8 .032" (0.8mm) $7.16 for the
plug
http://www.sparkplugs.com/results_cr...PR-P8&x=43&y=9
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 21, 2006 | 01:22 AM
iLLM3's Avatar
When the plugs hesitated under boost PSM/ABS would come on before realizing/changing them out, CEL never came on, which is why i also think its plugs!
Goodluck
Old Dec 21, 2006 | 02:51 AM
RT7's Avatar
RT7
Show-N-Go like J-Lo Mofo
RT7 is infamous around these parts
It couldn't be MAF, most likely it's the plugs.
Old Dec 21, 2006 | 11:43 AM
topgun's Avatar
topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !
[quote=RennTechV12]I've blown several MAFs while in the testing phase; both in my TT and the GT2, and the car ran fine. I got a small hesitation and lifting of power when the actual MAF blew, then the car ran fine.
I had the same result!
Old Dec 21, 2006 | 04:13 PM
Alright, so the final outcome was - MAF I took it down to Todd at EVOMS and he gratiously got me in right away and hooked the computer up and it was a blown MAF....
I had a new one installed and the fault codes went away!
Thanks everyone for the help and thank you - Todd!
Old Dec 21, 2006 | 05:47 PM
RennTechV12's Avatar
RennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond repute
Cool, that's an easy fix. I've been through too many not to recognize those symptoms
Old Dec 21, 2006 | 05:50 PM
Yup, all fixed now! Now I can go beat up some cars on the 101......
Bmw M3 Guy
Feb 21, 2018 09:29 AM
randalldahme
Feb 19, 2016 03:56 PM
ophtho
Sep 18, 2015 03:00 PM
JWrightPNH
Sep 17, 2015 01:42 PM
dgreen78
Cayenne 955/957
Sep 12, 2015 11:44 AM
