Installing used abs pump, programming question
Old Sep 11, 2015 | 03:02 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Needing to install a used replacement abs pump in a 08 cayenne. Wondering if this is a plug and play install or if it needs to be programmed to vehicle? If so, will a PIWIS handle the programming?
Old Sep 12, 2015 | 11:21 AM
Mr. Haney's Avatar
Mr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to behold
I'm not positive but I think the problem will be activating the pump and all the solenoids/valves to get it bled correctly. The abs control module shouldn't be part of the equation.
Old Sep 12, 2015 | 11:34 AM
Serg124's Avatar
Serg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond repute
not even close. brakes bleeds without any problem without any "activation"
Old Sep 12, 2015 | 11:44 AM
Serg124's Avatar
used pump can be a problem. need to be exact matched partnumbers, or possibility of errors is very high. new pump coded to vehicle once, PIWIS can solve many problems but not this one...
km90265
Aug 31, 2015 11:00 AM
JMon
Aug 21, 2015 08:20 AM
Aug 21, 2015 06:34 AM
Nissan GTR
Aug 19, 2015 02:11 PM
