So who ports and polishes stock headers?
Old Dec 22, 2006 | 12:48 AM
cpu77's Avatar
cpu77 is infamous around these parts
Thinking of getting my stock headers ported and polished. Whats it cost and who does it? I am not sure if I will do this right now cause I am trying to buy some new turbos
Ralph
Old Dec 22, 2006 | 12:57 AM
I do... LOL u can do it urslef... and get them polished for $160.
Go to any tuning shop that does JApanese cars... show them pics of what u want..... have them do it.... should take a couple of hours...
if u want it done by a Pro call Kevin..
markski
ps. Im speaking form experience...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 22, 2006 | 03:14 AM
sharkster's Avatar
Making holes smooth. There is more than one way to skin a cat just like Marksi says...
Old Dec 22, 2006 | 03:19 AM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
Would there be a noticeable improvement or should I say worth spending the time/money on?
Old Dec 22, 2006 | 03:32 AM
sharkster's Avatar
Depends what other mods you do/don't have. The first few things you should already have before doing anything like that would be:
1)Chip tuning
2)Exhaust
3)Diverter Valves
4)SSK
Then a few other things here and there and then maybe worry about the headers...
Old Dec 22, 2006 | 08:49 AM
Acropora's Avatar
Acropora has a spectacular aura aboutAcropora has a spectacular aura about
I've never seen a before and after dyno showing this makes any difference at all. Maybe someone has some.
Old Dec 23, 2006 | 10:46 PM
ebaker's Avatar
ebaker is infamous around these parts
I remember one of the Guru's saying it gave 7 HP.
Old Dec 23, 2006 | 11:01 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
seem to remember 7hp too. think it's a % thing. so it would increase with additional mods
Old Dec 24, 2006 | 12:13 AM
oak's Avatar
oak
it's comes natural. you have smoothed out holes before havn't you?
oak's Avatar
oak
I think 7 hp would be pushing it.
Old Dec 24, 2006 | 10:17 AM
wross996TT's Avatar
Maybe knit picking here, but it can't possible add hp (it does not generate power). What it does is allow for better air flow so you can take advantage of the power you already have.
Old Dec 24, 2006 | 11:01 AM
ebaker's Avatar
More flow = more power if the exhaust gas velocity doesn't drop.
Old Dec 24, 2006 | 04:16 PM
oak's Avatar
oak
imho, it's a waste of time unless you have mucho time on your hands. you would fair much more results if you ported the exhaust ports on the head. too much work for no gain, port the other side.
think about it, as the exhaust gases pass through the ports on the heads the it's flow is limited to the size and shape of the ports in the heads. the factory header tubes are flared past the flange to open up a chamber between the ports and turbo where the gases collect. also the factory header flanges are fairly closely matched by making them larger than the ports on the heads is imho a waste of time. a psychological advantage if that.
Old Dec 24, 2006 | 04:22 PM
Its all about velocity.... Stock headers are said to be great.... port them well and u will see the difference.... I know first hand...
Divirextreme is the fastest 6speed member running 10.6 @ a whopping 136 mph on stock motor...HE IS ON STOCK HEADERS my friends... stop fooling yourselves.... When you go up to 650+ hp one may consider aftermarket headers...
just my opinion.
markski
9.66
click to view
Old Dec 24, 2006 | 05:47 PM
K24madness's Avatar
K24madness is infamous around these parts
If you have your turbos off this is a worth while mod. The gains will be seen mostly in spool up and slightly in overall HP.
If you are willing to remove the turbos, send them to Protomotive and have the larger 18g compressors installed. Combine this with his program and you will have less lag than your current K24's and waaaay more HP.
