Gas gauge problem?
Old Feb 21, 2004 | 08:24 AM
Rave TT's Avatar
Happy Now?
Rave TT is a jewel in the roughRave TT is a jewel in the roughRave TT is a jewel in the rough
Gas gauge problem?
My gas gauge is very temperamental, sometimes it reads zero gas is left, when I go to fill up it only take 9 gallons, sometimes it works fine (of course it never acts up around the dealer), anyone else here have problems with the gas gauge?
Old Feb 21, 2004 | 09:03 AM
dbelleperc's Avatar
I soon will be a supporting member
dbelleperc is infamous around these parts
What year is your car? Because I think that there was a TSB for the gas gauge.
Old Feb 21, 2004 | 09:07 AM
Rave TT's Avatar
Happy Now?
Mine is an 01, what is a TSB?
Old Feb 21, 2004 | 09:12 AM
dbelleperc's Avatar
It is a (Technical Service Bulletin) and it did affect early 99-01 cars.
dbelleperc's Avatar
You need a software update.
Old Feb 21, 2004 | 09:13 AM
Rave TT's Avatar
Happy Now?
Thanks.
Old Feb 21, 2004 | 09:14 AM
cjv's Avatar
cjv
Moderator
If the battery ran down, you need to re caliberate the fuel gauge if at the time of the run down you had less than a full tank. You do this by filling the tank 100% after the battery has been recharged. The gauge will then reset and be correctly calibrated once the tank is refilled.
Old Feb 21, 2004 | 09:31 AM
dbelleperc's Avatar
You might just want the dealer to hook up the PST2 and check what version of software you are running. Version 8.2 or higher.
Connect the PST2 and switch on the ignition,
Select vehicle type and select (996) and start search with >>
Select instrument cluster and press >>
Select modify coding and press >>
Select tank characteristic and update with FB.
Return to start menu and switch off PST2.
Old Feb 21, 2004 | 09:32 AM
dbelleperc's Avatar
But I would try CJV's way first.
Old Feb 21, 2004 | 10:51 AM
DrJim's Avatar
DrJim is infamous around these parts
I would think Dr. Bill owes you at least a night out in NYC with one of his wife's friends for taking that car off his hands. Don't let him off the hook so easy and I have his home phone # in case he won't answer his cell.
Old Feb 21, 2004 | 02:22 PM
Rave TT's Avatar
Happy Now?
ha ha, it’s not Bills fault the service dept at silver star didn't fix the problem / my experience with them sucked.
Old Feb 22, 2004 | 06:35 AM
Red Devil's Avatar
Red Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to all
I've been told, but haven't seen for myself yet, that they are one of the best around.
Old Feb 22, 2004 | 08:09 AM
msindi's Avatar
dunno if this is a realted problem but my on board computer MPG display seems to never change!!! it is and has been at 10.8 MPG for a looooooong time now....
Old Feb 22, 2004 | 09:39 AM
dbelleperc's Avatar
Mansour, don't put so much pressure on the right peddal.
Old Feb 22, 2004 | 03:41 PM
drbill's Avatar
drbill is infamous around these parts
Jim, Ron and I actually were out together last night - had a great time. Ron, had lots of fun at Marquee and looking forward to seeing you and John again. Dr Jim(aka Mr. Spacey), by the looks of your early Sunday morning post it looks like you had another wild and crazy all-nighter with the misses-both sleeping around 11 pm i assume (yawn)
