2.5 or 3" exhaust piping for 600HP
Old Dec 23, 2006 | 01:21 AM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
I am planning to do a custom exhaust like Craigs (no cats, w/resonators). My goal in a few months is to have the K24/18G Protomotive package and be pushing a little over 600hp. My thoughts are that 2.5" piping will be fine at this point? Am I correct or will going to 3" be beneficial? The outlets of the stock turbo are 3".
Will there be a big sound difference between 2.5" and 3"? I noticed most all aftermarket systems are 2.5"
Old Dec 23, 2006 | 03:49 AM
Turbo Fanatic's Avatar
The bigger the better on a Turbo car. Yo may lose a bit of pre-turbo torque, but will breather much better under boost.
My Remus Exhaust comes with 3.15" piping (80mm) in Euro Spec.
Old Dec 23, 2006 | 05:45 AM
I have 3 inch piping......
this will not make a whole lot of difference.... make sure ur neighbors are cool with loud exhaust.... mine almost shot me...
what will make a difference is porting ur stock exhaust....
Also, get a clutch....
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 23, 2006 | 06:37 AM
SMR's Avatar
SMR
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
2,5 inch will do, rember you have 2 of them
Old Dec 23, 2006 | 10:49 AM
cjv's Avatar
cjv
Moderator
If 600 hp is your goal, the 2.5 will not be a restriction. It will be more than enough.
Old Dec 23, 2006 | 12:49 PM
Bodybag's Avatar
Bodybag has a spectacular aura aboutBodybag has a spectacular aura about
A 3.6 litre engine @ 1bar is breathing roughly 440 cubic inches of air per cycle. There is not a hot rodder around that would suggest putting 2.5" exhaust on a 440ci engine spinning 6500-700rpm.
On a turbo motor, post turbo exhaust flow is even more critical than on an NA motor. In the lower rpm range the 2.5" pipes will be enough, but once you start spinning it up the 3" pipes will be a payoff.
If you're going to be a bear... be a GRIZZLY!!!
Old Dec 23, 2006 | 02:49 PM
SMR's Avatar
SMR
You are missing 2,5 inch for 1,8 liter will support alot, like 350-400hp
Old Dec 24, 2006 | 04:41 PM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
Why not go straight to 3 in. Yes, it is a bit more work to construct the exhaust, but then you will have ample flow to grow into.
Beware, the sound your exhaust will produce is not for the faint of heart.
Craig
Old Dec 24, 2006 | 04:50 PM
dgreen78's Avatar
Thats the problem is that I dont think my neighbors will like me anymore if I do go the 3" route. I would think the 2.5" would be a little quieter? I am also going to make some 3" straight pipes for track days. When I get everything completed I will dyno the differences.
Old Dec 24, 2006 | 07:57 PM
iLLM3's Avatar
LOL if that is your reasoning for not going 3" then dont worry about it. The 1/2 inch wont make the exhaust that much quieter, a straight through exhaust will be LOUD AS HELL no matter how you look at it, 2.5 or 3" doesnt matter!
Old Dec 25, 2006 | 10:26 AM
WOODTSTER's Avatar
Dgreen,
talk to Todd, he will let you know your anwers.
MK
Old Dec 25, 2006 | 11:10 AM
grussell's Avatar
grussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud of
I have one for sale just like Craig's and built in the same shop. Why don't you just buy mine?
https://www.6speedonline.com/forums/...ighlight=burns
Old Dec 25, 2006 | 12:55 PM
Craig's Avatar
No point starting from scrath . . . might as well buy GR's unit!!!
Craig
Old Dec 25, 2006 | 12:58 PM
grussell's Avatar
Craig
Thats what I thought.
Old Dec 26, 2006 | 05:54 PM
J.Moss's Avatar
J.Moss is infamous around these parts
I have seen your car at Lucent a few times and the exhaust is really nicely fabricated. But not for the faint of heart!
